Simon Bridge said:
I don't think that means anything - you can only have motion wrt a rest frame ... which is the frame in which some observer is at rest.
You can talk about how the rest frame of an object is moving wrt the rest frame of another object - in special relativity that would just involve stating the relative velocity of the two frames. But in that case, "frame" has the same meaning as "rest frame". You've seen this in introductory lessons which talk about the S frame and the S' frame. S' is the rest frame of observer O' and S is the rest frame for observer O. It is usually set up so that S' moves at speed v in the +x direction in frame S while S moves at (the same) speed v in the -x direction in the S' frame.
I understand that.
Simon Bridge said:
... um... when the receiver moves away from the emitter, the wave peaks arrive further apart in time - which results in the reduced frequency.
You could look it at that way too. When a train blows its whistle while moving away, the sound waves must cover the extra distance before reaching the observer. Doesn’t a moving light source follow the same principle? We have red-shifts to indicate stars are moving away.
Simon Bridge said:
Or do you really mean that the farther apart receiver and emmitter, the longer the wavelength?
Not quite. If emitter and receiver are not moving with wrt each other then the wavelength is what it is in the rest frame of the observer. You need to introduce acceleration in an orbit for asymmetry to arise.
Simon Bridge said:
Even when they are stationary with respect to each other?
This is the fascinating part. They are not exactly stationary; one body is rotating about the central observer. It was pointed out to me that the central observer will receive red-shifted signals from the rotating emitter, while the rotating emitter must therefore receive blue-shifted signals from the central emitter. Again, it was pointed out to me this is called the transverse Doppler effect. Yet the signals are not covering any extra or lesser distance, they are only covering dilated time and contracted time, if that makes sense.
Simon Bridge said:
Note: gravity is subject to GR, your questions are in SR. Please try to avoid mixing the models up.
You also need to be more careful with your descriptions ... i.e. Time has only one dimension so it cannot have a volume. So what is it that you are calling a "time volume"?
Time is a scalar; distance is a vector. So yes, it is alien to speak of time as having volume. But in a strictly confined context you can use it to describe a calculation. I’ll try be careful...and I will claim in advance there is nothing new about it, or contradictory. Here goes:
It strikes me that in the rotation case we have GR and SR rolled into one. There is constant acceleration of the angular velocity- that’s the GR part- and there's time dilation and length contraction- which is the SR part. After a few steps in calculation, we find the diagonal path (DP) traced by a photon in a moving light clock relative to a "stationary frame" may be given as 1h/(c^2-v^2)^{1/2}, where h is the separation between the mirrors. It turns out the result is always longer than 1 for the light clock that is moving (when viewed from a stationary frame). Now, imagine the DP of a photon in a light clock that is momentarily co-moving with the rotating frame for some very short distance at uniform speed (i.e. as part of a polygon fitted around the circle). Then the wider DP for the co-mover compared to the vertical path traced by a photon in a relatively “stationary” light clock (which
always equals 1h/c) must correspond to a higher frequency of received wavelengths if sent from the central frame. So the wider DP
exactly equals the time dilation factor, 1/(1-v^2/c^2)^{1/2}, if you substitute 1 for h in the first equation. This surely isn’t new.
When I think of dilation I think of something that "dilates" like the pupil in the eye. The higher received wavelengths (the Transverse Doppler effect) “fit” into the dilated dimension of the rotating frame. Because the dimension is dilated, more wavelengths have to be accommodated for each “tick” of the clock that approaches synchronization with the earlier mentioned co-moving light-clock. Therefore the wavelengths travel longer in the dimension of time (from the "stationary" view) just like they travel longer in the dimension of distance between widening inertial frames. We can view it as a
relativistic time expansion so the properties of mass expand
relativistically too, which in no way should be confused with absolute quantities of mass.
Simon Bridge said:
The old "relativistic mass" is better understood as part of kinetic energy. "Rest mass" is just "mass" or "invarient mass". You are correct that it is easy to get confused when you use the term "relativistic mass" - so just don't use the term.
There are interesting papers pro and against the use of “relativistic mass”. Some properties depend on motion relative to the observer (TR Sandin, In Defense of Relativistic Mass, American Journal of Physics, 1991) I found Sandin’s argument persuasive. Rest mass is rest mass, which does not change just because its relativistic mass changes. Anyway, that sounds like another thread starter. But I think it comes down to being careful with the term and its correct context, rather than total avoidance.
