Engineering Why is a bridge rectifier necessary in this circuit?
  • Thread starter Thread starter Femme_physics
    Bridge Diode
A bridge rectifier is essential in this circuit to allow current to flow during both the positive and negative cycles, ensuring that the load receives a continuous voltage. When diodes D1 and D2 are short-circuited, only the positive cycle is modeled, which limits current flow. The SCR in the circuit blocks the negative cycle, preventing any voltage from reaching the load unless a bridge rectifier is employed. This configuration enables the circuit to effectively convert AC to DC, providing a stable output voltage. Understanding the role of the bridge rectifier is crucial for accurate calculations of average voltage across the load.
Femme_physics
I am told that in this circuit (above pic) we shortcircuit D1 and D2, and disconnect D3 and D4... then we are to calculate Vrl(average)
But the way I see it, if we shortcircuit D1 and D2 the entire circuit is shortcircuit and current only flows like this (below pic)
http://img195.imageshack.us/img195/8396/d1d2d3.jpg
When the question asks "shortcircuit D1 and D2", I think it means: "replace D1 with a wire and replace D2 with a wire"
Yep.
And disconnecting D3 means taking D3 out.
So there cannot go current anymore through the place where D3 used to be...
Yep. The current would flow like that. :)
What about that block on the right? What does it do?
Does it draw any current?
And is the SCR always conductive?
Doesn't that depend on the voltage at its gate?
So current only flows at the positive cycle
Yes and no. You have only modeled the positive cycle.
To model the negative cycle put the diodes back and pretend the other two are shorted/conducting.
The block to the right is a circuit to control firing angle (At 30 degrees).
CWatter - There is no negative cycle. The SCR blocks it! All the voltage falls on the SCR and nothing on the load.
Okay.
Then I guess you are set to calculate the average Vrl.
Perhaps you can explain why a bridge rectifier is needed then :-)
