- #106
- 24,017
- 3,337
:grumpy: The trees with overhead branches are the weeping willow and the japanese plum, the dead tree is a little plum tree.Jeff Reid said:Ok, so this wasn't a case of an excessively blonde moment.
:rofl: :rofl: :rofl: :rofl: :rofl:Jeff Reid said:That would be Weapons of Member Detachment?
Now that's the most convincing reason I've heard so far! See that Evo? Hiring someone else will actually save money, and then you can use all that extra money to go to the spa! It doesn't get much better than that.turbo-1 said:You should consider hiring someone to do the trimming, and spend the saved emergency-room co-pay on a nice spa treatment.
My emergency room co-pay is only $40 and I have dismemberment insurance at work that pays a lot for losing body parts. But, I happen to be attached to my body parts, so I'd rather not collect.Moonbear said:Now that's the most convincing reason I've heard so far! See that Evo? Hiring someone else will actually save money, and then you can use all that extra money to go to the spa! It doesn't get much better than that.
Dynamite is a lot easier. Evo apparently lives in Texas, so she should be able to go to the local K-Mart children's gun and explosive's department and pick up what she needs. Then again, a fully automatic weapon (borrow one from a shooting range, quite common in Texas), would make short work of those branches. Weapons of choice in Texas are a bit different than most places. For example, in Texas, automobiles are the weapon of choice for eliminating ex-hubbies.scalping the stumps
You know where the PF chainsaw is and your killed franzbear...yomamma said:Use the PF Chainsaw...it should be here in the basement...
Uhm, I'm 5'3" and these branches are probably 5' 7" off the ground, but that put's them overhead.Jeff Reid said:Dynamite is a lot easier. Evo apparently lives in Texas, so she should be able to go to the local K-Mart children's gun and explosive's department and pick up what she needs. Then again, a fully automatic weapon (borrow one from a shooting range, quite common in Texas), would make short work of those branches. Weapons of choice in Texas are a bit different than most places. For example, in Texas, automobiles are the weapon of choice for eliminating ex-hubbies.
Ok back to reality, I'd recommend contacting some tree trimmers. You're trees aren't that big and it shouldn't cost that much to take care of them.
You didn't state how high up the branches that need trimming are, so I don't know what's involved. If it's climbing gear, I'd stick with professionals.
If you do hire an amatuer, I'd recommend tying a rope relatively high on the small tree, to guide where it falls. The tree is mostly likely off balance and will just fall to the heavy side regardless of the cut pattern used on the trunk. It's possible that you can just pull on the rope to take down the tree. Use a long enough piece of rope so you don't get hit by the tree or any tree related shrapnel. If you soak the ground around the tree trunk first, you might get lucky and pull the whole tree out, depending on what condition the roots are in.
For the branches you want to trim, there are saws and clippers mounted to poles for just this purpose, but this can be tiring if the branches are relatively large, and where do you store this stuff when you're not using it (unless you can rent it).
Still as others have already posted, seems like getting some tree trimmers to do the job is the smartest way to go.
Maybe you just need to wrap the branches in bacon and let the Jaws of Death do the dirty work.Evo said:I just need to buy another pair of extension lopers like the one the JAWS OF DEATH ate.
She could probabaly learn to levitate if I did that. Might freak the cats out.Moonbear said:Maybe you just need to wrap the branches in bacon and let the Jaws of Death do the dirty work.
Pet of yours? Maybe if you locked it up, you might get some help.JAWS OF DEATH
OK, isn't there some nice fellow here willing to help out a poor defenseless woman protect herself from some evil tree branches?Uhm, I'm 5'3" and these branches are probably 5' 7" off the ground, but that puts them overhead. You're killing my thread, I'm trying to milk sympathy out of people
Maybe I was a bit unfair about this, I should explain that it's not as bad as it sounds. The childrens department doesn't have anything bigger than a 50 caliber machine gun, and as far as explosives go, just blasting caps and dyanmite. Plus these products are labeled for ages 9 and up, so it's not like just any kid could buy this stuff. You have to be an adult to get the true home protection weapons and the really good stuff, like a 20mm gattling gun or c-4 explosive.Texas K-mart children's gun and explosive's department
:rofl: She's originally from TX, but doesn't currently live there. And, now, you're exaggerating a tad. You have to be at least 12 to get the machine guns and dynamite. 9 year olds only get shot guns and rifles...nothing semi-automatic or automatic until they've learned to be a bit easier with the trigger finger.Jeff Reid said:Maybe I was a bit unfair about this, I should explain that it's not as bad as it sounds. The childrens department doesn't have anything bigger than a 50 caliber machine gun, and as far as explosives go, just blasting caps and dyanmite. Plus these products are labeled for ages 9 and up, so it's not like just any kid could buy this stuff. You have to be an adult to get the true home protection weapons and the really good stuff, like a 20mm gattling gun or c-4 explosive.
Ok, I sit corrected. I'm originally from Texas as well. Born in Houston, but now I'm living in southern California, about 20 miles SE of Disneyland (no sign of ZapperZ though).Moonbear said:She's originally from TX, but doesn't currently live there. And, now, you're exaggerating a tad. You have to be at least 12 to get the machine guns and dynamite. 9 year olds only get shot guns and rifles...nothing semi-automatic or automatic until they've learned to be a bit easier with the trigger finger.
