Show ##(\frac{\partial S}{\partial G})_Y = -\frac{C_Y}{TS}##
To show that the partial derivative of entropy with respect to Gibbs free energy equals negative heat capacity divided by temperature and entropy, the relationship between Gibbs free energy, enthalpy, and temperature must be utilized. The equation dG = dH - TdS - SdT is central to this derivation. The confusion arises from the variable Y, which may actually represent volume (V), complicating the differentiation process. Clarification on the variables and their meanings is necessary to proceed with the solution. Understanding these relationships is crucial for successfully completing the homework problem.
GL_Black_Hole
Show that ##(\frac{\partial S}{\partial G})_Y = -\frac{C_Y}{TS}##
##G = H-TS, (\frac{\partial H}{\partial T})_Y = C_Y##
##dG = dH -TdS -SdT## and ##H## is a state variable so ## dH =\frac{\partial H}{\partial T} dT + \frac{\partial H}{\partial Y} dY##. Not sure how to use the given information or continue from here.
What you have written makes little sense. I do think the ## Y ## my actually be a ## V ##, but to take the partial derivative of ## S ## w.r.t. ## G ## is also rather odd.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
