Show that f(x) = sin(x^2) is continuous for all a [-sqrt(pi), sqrt(pi).
  • Thread starter Thread starter Robultronic
    Continuous
Robultronic
Given f : [-\sqrt{\pi}, \sqrt{\pi} ] \rightarrow [-1, 1]
f(x) = sin(x^{2})
a)
Show that f is continuous for all a \in [-\sqrt{\pi}, \sqrt{\pi} ]
b)
Find a \delta so that |x - y| \leq \delta implies that
|f(x) - f(y)| \leq 0.1 for all x and y in [-\sqrt{\pi}, \sqrt{\pi} ]
I honestly don't know where to begin. But would be very pleased for any help. A full solution would be the optimal though. But anything helps.
If you want to go back to the definition of continuity, you need to show that for every point a in the interval,
\lim_{x \to a} f(x) = f(a)
(with the appropriate one-sided limit at the endpoints). If you can assume other facts, then you can argue f(x) is continuous in a less tedious way. What do you think you're supposed to do?
I'm supposed to use the definition of continuity.
I know how to show continuity at a point, but have no clue of how to do it for an interval.
You just have to show f is continuous at every point in the interval. It essentially amounts to saying "Let a∈[-√π,√π]" and showing f is continuous at x=a like usual.
Lol, that simple, thx. I kept thinking I had to use the interval in the proof somehow and not just say a = the interval. OK, that I can do. How about b?
I think I solved it, I will write it down when I get home so someone can tell if its correct or not, but have to go now.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
