Show that this piecewise function is continuous at 0
Mr Davis 97
##f(x) = x \sin (\frac{1}{x})## for ##x \ne 0## and ##f(0) = 0##. Prove that this function is continuous at 0.
First, I need to look at the quantity ##|f(x) - f(0)|##. However, I am not completely sure how to proceed. I would think that we substitute ##x \sin (\frac{1}{x})## for ##f(x)##, but is this justified? Why can we guaruntee in this case that ##x## won't assume the value of 0 and hence be 0 rather than ##x \sin (\frac{1}{x})##?
Depending on how rigorous your argument needs to be, you might not need to look at this difference.
One definition for the continuity of function a at a number ##x_0## in its domain is this: ##\lim_{x \to x_0}f(x) = f(x_0)##
Because in the definition you're dealing with a "punctured neighborhood" around 0.
I.e., if ##0 < |x - 0| < \delta##
You can't substitute that value if you want to use epsilon delta definition.
You can however consider two cases: namely x = 0 and ##x \neq 0##. The former case gives always 0, so you can safely assume ##x \neq 0## and then you are allowed to plug in the expression.
It then boils down to estimating ##|x \sin(1/x) - 0|## for ##x \neq 0##, given that x is small, which ought to be straightforward.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
