Show Two Positions of Converging Lens for Sharp Image Formation
  • Thread starter Thread starter leolaw
    Converging Lens
A converging lens can produce a sharp image of a bright object placed at a distance d_T from a screen, with two distinct lens positions when d_T exceeds 4f. If d_T is less than 4f, no sharp image can be formed regardless of the lens position. The relationship between the object distance (o), image distance (i), and focal length (f) is described by the lens equation, leading to a quadratic equation that determines the conditions for real image formation. The distance between the two lens positions and the ratio of image sizes can also be derived from these equations. Understanding these principles is crucial for solving problems related to lens optics.
leolaw
A bright object is placed on one sid eof a converging lens of focal length f, and a white screen for viewing the image is on the opposite side. The distance d_T = d_i + d_0 between the object and the screen is kept fixed, but the lens can be moved.
Show that if d_t > 4f , there will be two positions where the lens can be placed and a sharp image can be produced on the screen.
And if d_t < 4f, no lens position where a shakrp image is formed.
Also determine a formula for the distance b/w the two lens position,and the ratio of the image sizes.
the attachement is the work that i was trying figure out how to do it. but i don't seem to know how to tackle this problem
You'll need to do some rearranging of equations and plugging in, try finding dt as a function of f.
From the lens equation:
\frac{1}{f} = \frac{1}{i} + \frac{1}{o}
since S = i + o (S = object to screen distance):
\frac{1}{f} = \frac{1}{i} + \frac{1}{S-i}
This gives you a quadratic equation in terms of i. Solve that using the quadratic formula and you should get two solutions for i:
i = \frac{S \pm \sqrt{S^2 - 4Sf}}{2}
AM
after \frac{1}{f} = \frac{1}{i} + \frac{1}{S-i} , I have f = \frac{si - i^2}{s} , and then i set the equation equals to zero: i^2 + fs - si = 0, but i don't get how you can solve for i from i = \frac{S \pm \sqrt{S^2 - 4Sf}}{2}.
Well, you can't solve for i unless you know S. But that is not what the question asks.
What is the condition for i to be real? What is the condition for i to have 2 real values?
AM
for i to be real and have two solutions, \sqrt{S^2 - 4Sf} must be greater than 0.
So, s^2 - 4sf > 0
s^2 > 4sf
s > 4f and we set s = i + o before, so we get the answer for the first two questiosn.
But I don't know how you can get i = \frac{S \pm \sqrt{S^2 - 4Sf}}{2}, from i^2 + fs - si = 0
So, s^2 - 4sf > 0
s^2 > 4sf
That is just the quadratic formula. The general quadratic equation:
ax^2 + bx + c = 0
has solutions:
x = \frac{-b \pm \sqrt{b^2-4ac}}{2a}
In this case, a = 1, b = -S, c = sf
AM
ax^2 + bx + c = 0
has solutions:
AM
AHAHHAHHAHAHA. I feel myself really stupid now...can't even find the coeiffient term of a quadratic equation!
That happens during exam time! Ease up .. it was a bit of a tricky question.
AM
