Andrew Mason said:
Or, if you started with the conservation of angular momentum you could derive the laws of linear motion (eg. a special case where the radial force is 0). In physics, there are no real fundamental axioms. Everything is derivable from everything else, it seems. What is considered fundamental is a matter of the approach one takes.
I'll go one step further, I think there aren't any axioms in the first place.
In physics "axioms" serve a different purpose than in mathematics. In physics the purpose of the axioms is to be
evocative.
It's not necessary for any physics discipline to lend itself to axiomatization. There are no axioms for maxwellian electrodynamics; I'm not aware of any axioms of quantum mechanics.
It just so happens that in a couple of physics disciplines it is possible to capture the contents in a small set of principles. There are the laws of thermodynamics. In mechanics there are the laws of motion. The circumstance of being able to formulate a small set of principles, and have pretty much all the bases covered is actually exceptional to the general state of affairs.
For mechanics it does seem to me that linear momentum is more fundamental than angular momentum.
We have the following law of conservation of linear momentum: When two particles exert a force upon each other (repulsing or attracting/colliding) then the state of motion of the center of mass remains the same.
That kind of interaction requires only one dimension of space. Linear momentum is a one-dimensional phenomenon, in the sense that for linear momentum to exist one spatial dimension is sufficient.
Angular momentum is inherently a phenomenon in two spatial dimensions. Two particles can have angular momentum relative to their common center of mass when they are circumnavigating each other. Geometrically angular momentum is proportional to an
area, rather than proportional to a vector.
Circumnavigating motion sweeps out a
plane, and to specify angular momentum you must specify that
plane. Since our space has three spatial dimensions it so happens that we can specify the angular momentum plane with a vector. As we know, the angular momentum vector is defined as the vector that is perpendicular to the angular momentum
plane.
Summerizing:
For linear momentum one spatial dimension is sufficient; angular momentum is inherently a phenomenon in two spatial dimensions.
