Showing every free module is Projective
  • Context: Graduate
  • Thread starter Thread starter Phillips101
    module
4 replies · 6K views
Phillips101
Take P a free module over an arbitrary ring. Show P is projective.
Definition of Projective:
If f: M-->N and g: P-->N are module homomorphisms with f surjective, then if P is projective there exists homomorphism h such that h: P-->M with f(h(x))=g(x) for all x.
Obviously f has a right inverse, and so it is easy to find an h that works, but not a homomorphism h that works. I really have no idea about this and help would be appreciated.
Second bit:
Conversely, show that if P is a projective module over a Principal Ideal Domain, then P is free.
You have the definition of projective wrong:
P is projective iff:
For all homomorphisms f:M->N and g:P->N:
If f is surjective, then:
There exists a homomorphism h:P->M with fh = g​
Anyways, isn't the set of all homomorphisms P->M easy to describe, when P is free?
I can't see a difference between our definitions, but yours is certainly clearer.
I don't know what that would be. I'd hazard a guess at matrices, but surely that relies on M being free as well?
I hate to just blurt out the answer to my question -- it's probably the most important property of free modules and I want to give you a chance to recall it, but anyways...
If F is the free module on a set X of generators, then any function X-->M uniquely extends to module homomorphism F-->M. Conversely, any module homomorphism F-->M is completely determined by its values on X
The difference between the definitions we gave is the order of quantifiers. e.g. by your definition, Z/2 would be a projective module over Z, as follows:
Let M = Z/2 and N = Z/2.
Let f:M->N and g:P->N be the identity homomorphisms.
Note that f is surjective.
Your definition says that I can now prove P projective, by letting h:P->M be the identity, because fh=g.
However, the correct definition is univerally quantified over M,N,f, and g. I don't have to be able to find an h for just one particular choice of M,N,f,g -- I have to be able to find an h for every choice of M,N,f,g.
About the spoiler; I didn't cover that in my course, I just checked my notes. But, it is fairly 'obvious' when you consider vector spaces, so I suppose I was just supposed to deduce it.
And I see the difference now.
Thanks for the help, I'll have another go at the problem.
