Showing that a discontinuous function is integrable
  • Thread starter Thread starter Faris
    Function
Faris
Hi,
First, I want to thank you people for the help.
1. Define a function f by setting f(x)=1 if x=1/m for some positive integer m (e.g. f(1)=1, f(1/2)=1, f(1/3)=1,...) and f(x)=0 otherwise. Show that f is integrable on the interval [0,1] by proving that the limit of the lower Riemann sums for the regular partitions P_n equals the limit of the corresponding upper Riemann sums.
2. Lower Riemann sum = L(f,P_n)
Upper Riemann sum = U(f,P_n)
3. I've tried the following argument, but I don't think it's enough for a proof:
L(f,P_n) = 0 because by taking n to infinity, the minimum values for f(x) in the delta x's are zeros, which makes L(f,P_n)=0.
U(f,P_n), however, is the problem here.
Thanks in advance.
Hint: If you have a partition P_n, then each piece of a partition that contains a point where f is nonzero has an area of \frac{1}{n}. What you need to show is that for any \epsilon, there is an n such that no more than n\epsilon of the pieces contain a point where f is nonzero.
Try to do this example and you'll probably get the idea of the proof:
Exercise:
Let \epsilon=0.1. Show that you can make U,P_{1000} \le \epsilon by covering every value 1/n (for positive integers n) by selecting 100 intervals from P_{1000}.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
