Showing that a near earth orbit is P = C(1 + 3h/2R_E)
  • Thread starter Thread starter jeanbeanie
    Earth Orbit
The discussion revolves around demonstrating that a satellite in low-Earth orbit can be approximated by the equation P = C(1 + 3h/2R_E), where h represents the satellite's height, C is a constant, and R_E is the Earth's radius. Participants explore the implications of this equation and the relevant physics concepts involved.
  • Participants discuss the use of Taylor series and derivatives to approach the problem. There are attempts to relate the semi-major axis to the radius of the Earth and the height of the satellite. Questions arise about the application of derivatives and how to approximate functions at specific points.
The discussion has evolved with participants sharing their understanding of derivatives and approximations. Some have expressed confusion about the application of these concepts, while others have attempted to clarify the relationship between the variables involved. There is an acknowledgment of the complexity of the problem, and some participants have sought further guidance.
Participants note that they have not covered certain mathematical concepts in class, which contributes to the uncertainty in their discussions. There is also mention of specific values and approximations that may not have been fully explored in the context of the original problem.
jeanbeanie
Show that a satellite in low-Earth orbit is approximately P = C(1 + 3h/2R_E) where h is the height of the satellite, C is a constant, and R_E is the radius of the earth)
p=C(1+3H/2R_E)
p2 = (4∏2)/(GM) * a3. (G - gravitational constant, M - mass of the Earth (in this case) and a = semi-major axis)
I've been googling this and I seen one person say use Taylor series. We have not touched that so I am pretty sure it isn't how I should be finding this
so the a is equal to the radui of earth, and its high
a=h+R_E
and i can write that as
a=R_E(1+h/R_E)
SO p2 = (4∏2)/(GM) * R_E(1+h/R_E)3.
I just saw in my noes that's if (4∏2)/(GM) can be cancled out if all meaurments are in Au's, years and solars mass.
Then Id get
p2 = R_E(1+h/R_E)3
and p= R_E(1+h/R_E)3/2
Now what?
Now you have to recall that ## \frac {df(x) } {dx} = \lim_{\Delta x \rightarrow 0} \frac {f(x + \Delta x) - f(x)} {\Delta x} ## which for some small ## \Delta x ## means that ## f(x + \Delta x) - f(x) \approx \frac {df(x) } {dx} \Delta x ##.
we have never done anything like this, I am not even sure were to start with it
You do not know what the derivative of a function is?
we we have done that, but I didnt get the second part
but now that I am more awake and looking at it again, does it mean
just take the dertive of the function that I already had?
The second part means that if you know the value of a function and its derivative at some point x, then you can approximate the value of the function at some close point, via the expression given. Note that you have a function which you want to compute at (1 + h/R). The function (and the derivative) at 1 are trivial, and (1 + h/R) is very close to 1 because h is much smaller than R.
So do you mean that p= R_E(1+h/R_E)3/2 is approximately
p= R_E(1*3/2
then
p= R_E
Then the derivative would be p=0
Or am I really wrong?
As shown above, ## f(x + \Delta x) - f(x) \approx \frac {df(x) } {dx} \Delta x ##. What would ## x ## and ## \Delta x ## be in this case?
isnt x the function?
p= R_E(1+h/R_E)3/2
and found Δx be the h/R because it is going to zero?
x is the independent variable. What is the function in your problem?
Ok, I really thought that the p= R_E(1+h/R_E)3/2 was the function
as in
p(h)= R_E(1+h/R_E)3/2
That is one possible choice of the function. Now you need to choose x and consequently Δx so that h = x + Δx. These are usually chosen so that f(x) and f'(x) are very simple.
like any x? like x and 1?
Or something to do with the problem like
R_E and 0?
Or would it have nothing do to with the eq?
Im really sorry, we never went over any of this is in class
Consider this very simple example. f(x) = x^2. Compute f(1.000001) using the derivative (the formula above).
right ok, woudlnt I just plug in the value for x as 1.000001?
Like
f(1.000001) = 1.000001^2
and
f'(x)=2x
f'(1.000001)=2(1.000001)
That did not use the f'(x)Δx formula.
ok
f(x+Δx)−f(x)≈df(x)/dx Δx
so 2x*Δx ? I do not understand what the Δx even is in this case
Do you see that if x = 1, then both f(x) and f'(x) are very simple? What is then Δx and what is f(x + Δx)?
I do see that f(x) = x^2 it would be 1
and in f'(x) it would be 2
f(x+Δx)−1≈2 Δx
f(x+Δx)≈2 Δx +1
Like I don't understand how to use the formula maybe? I understand what a derive is and how to plug and chug numbers, just not this formula or even how it applies to my problem. I am sorry
f(x+Δx)≈2 Δx +1 is not the complete answer. You were requested to compute f(1.000001) using the formula. You have the formula, but not the numeric result.
does that mean that x+Δx is the 1.000001?
Making Δx (1.000001 -1)/2
Yes. x + Δx must always be equal to whatever value we want to compute the function at.
What does this mean?
i ment Δx = (1.000001 -1)/2 which is really small? getting close to zero...
If Δx = (1.000001 - 1)/2, then x + Δx = 1 + (1.000001 - 1)/2 = 1.0000005, which is not 1.000001.
ok so
x + Δx = 1.000001
and i really have no clue.
f(x+Δx)≈2 Δx +1
f(1.000001)≈2 Δx +1? or am i still even using the right thing?
I do not understand why this is so hard.
x + Δx = 1.000001
x = 1
So 1 + Δx = 1.000001, giving Δx = 0.000001.
Apply the formula and check the result against 1.000001^2.
Then, consider this: f(x) = (1 + x)^2. Find the approximation for very small values of x. Note this function is very similar to the one you have in the original problem.
x + Δx = 1.000001
x = 1
Im sorry that I am having a hard time understanding
so df(x)/dx * Δx the dertivie of x^2 is 2x
so its 2x*1.000001
f(1.000001)≈2 Δx +1? if Δx =0.000001. so 2*0.000001 +1?
f(x) = (1 + x)^2
f'(x)= 2(1+x)
for very small values of x this would be 2, no?
As I said: Apply the formula and check the result against 1.000001^2.
Since you did not, now compute x^2 using the Δx method for 1.000002 - and please DO check the result against 1.000002^2.
the questions been resolved, thanks I went to see the prof
  • · Replies 17 ·
  • · Replies 29 ·
26K
