Showing that the following are equivalent
  • Thread starter Thread starter SithsNGiggles
    Equivalent
SithsNGiggles
I had this posted under a different question a while back and didn't get any responses, so I thought I'd rephrase it. I've reduced it to what I think I'm supposed to show. (Here's the old post: https://www.physicsforums.com/showthread.php?p=4260206#post4260206 ... Disregard the actual coefficients, I fudged those a bit.)
I have to show the following:
##||x||^2 = \frac{2}{3}|x_1|^2+\frac{1}{6}|x_1-\sqrt3x_2|^2+\frac{1}{6}|x_1+\sqrt3x_2|^2##
##x\in\mathbb{R}^2##, so ##x=(x_1,x_2)##, and the left side can be rewritten so that I have
##|x_1|^2+|x_2|^2 = \frac{2}{3}|x_1|^2+\frac{1}{6}|x_1-\sqrt3x_2|^2+\frac{1}{6}|x_1+\sqrt3x_2|^2##
Is there any way to do this?
|a + b|2 = (a + b)2
The rest is pretty basic algebra.
Merely expand the right hand side & collect terms.
SammyS said:
|a + b|2 = (a + b)2
Is it really that simple? I was getting the impression I couldn't do that. I thought for some reason that the sign of x1 or x2 would make a difference. Thanks a lot!
If a+b ≥ 0 , then it's pretty obvious that |a+b|2 = (a+b)2 , since |a+b| = a+b .
If a+b < 0 , then |a+b| = -(a+b), so that |a+b|2 = (-(a+b))2. But that's obviously equal to (a+b)2.
Oh I see it now, thanks! I was thinking that the sign of x1 and x2 would have some effect on the sum. Thanks again.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
