Showing two certain sets have no elements in common
  • Thread starter Thread starter k3k3
    Elements Sets
k3k3
Let x and y be irrational numbers such that x-y is also irrational.
Let A={x+r|r is in Q} and B={y+r|r is in Q}
Prove that the sets A and B have no elements in common.
Since x and y are in A and B, then x+r_{1}-y-r_{2} is irrational.
Using contradiction, assume their sum is z and z is an element of A\capB
x-y=z
Then x+r_{1}-y-r_{2}=z
Since z is in both A and B, then z can also be said to be x+r_{1}+y+r_{2}
Then x+r_{1}-y-r_{2}=x+r_{1}+y+r_{2}
Solving for the right side,
0=2(y+r_{2})
But since the sum is irrational and 0 is not irrational, A and B cannot contain the same elements.
Am I thinking about this correctly?
x and y are NOT in A and B, x+ r_1 and y+ r_2 are. And, from that, it follows that they are rational numbers so the difference is rational, not irrational.
x-y=z
0=2(y+r_{2})
x-y=z
0=2(y+r_{2})
No, if z is in both A and B, then z=x+r1=y+r2; then you take the subtraction ...
Did I show that x+r1-(y+r2)=x+r1-(y+r2)?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
