Finding Sides of an Oblique Triangle with Altitudes
  • Thread starter Thread starter darkmagic
    Triangle
To find the lengths of the sides of an oblique triangle using the three altitudes, additional information such as angles or specific lengths of the altitudes is necessary. The relationship between the altitudes and the sides can be explored through geometric principles, but without more data, the problem remains unsolvable. The discussion emphasizes the need for supplementary details to apply relevant formulas effectively. Understanding the properties of triangles and their altitudes is crucial for deriving the side lengths. Ultimately, the solution hinges on having more specific information about the triangle's dimensions or angles.
darkmagic
how can i find the length of an oblique triangle given the 3 altitudes (the line drawn perpendicular from a point of the triangle to the opposite side).
I have no idea on how to solve it.
Can you provide us with some more data you have for e.g angles or length of altitudes
The given is an oblique triangle. Find the length of the sides of that triangle.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
