Sign problem in laplace transform
Mechdude
\int_{\pi/2}^{\infty}cos(t)e^{-st}dt
\int vdu=uv-\int udv
v=cos(t) , dv=-sin(t)dt, du=e^{-st} , u=\frac{-e^{-st}} {s}
\int_{\pi/2}^{\infty}cos(t)e^{-st}dt = \frac{-e^{-st}}{s}cos(t) -\int (-)\frac{-e^{-st}}{s}(-)sin(t)dt
the right side becomes:
\frac{-e^{-st}}{s}cos(t) - \frac{1}{s} \int e^{-st}sin(t)dt
for the second integral on the right:v=sin(t) , dv=cos(t)dt and du=e^{-st} , u=\frac{-e^{-st}} {s}
\int e^{-st}sin(t)dt =- \frac{1}{s}e^{-st}sin(t)dt - \int \frac{-e^{-st}}{s}cos(t)
now \int_{\pi/2}^{\infty}cos(t)e^{-st}dt = \frac{-e^{-st}}{s}cos(t) - \frac {1}{s} \left[ - \frac{1}{s}e^{-st}sin(t) + \int \frac{e^{-st}}{s}cos(t)dt \right]
thus
\frac{-e^{-st}}{s}cos(t) + \frac {1}{s^2}e^{-st}sin(t) - \frac {1}{s^2} \int e^{-st}cos(t)dt
simplifying
\int_{\pi/2}^{\infty}cos(t)e^{-st}dt \frac {s^2 +1} {s^2}= \frac {1}{s^2}e^{-st}sin(t) - \frac{e^{-st}}{s}cos(t)
going on :
\int_{\pi/2}^{\infty}cos(t)e^{-st}dt = \frac {s^2}{s^2 +1} \left[ \frac {1}{s^2}e^{-st}sin(t) - \frac{e^{-st}}{s}cos(t) \right]
the right side is:
= \frac {1}{s^2 +1}e^{-st}sin(t) + \frac{e^{-st}}{s^2+1}scos(t)
now when i evaluate the limits:
=(0-0) - ( \frac{e^{-s\pi/2}}{s^2+1} - 0 )
=- \frac{e^{-s\pi/2}}{s^2+1}
im sure this is wrong because of the sign (its supposed to be positive now where did i drop the sign? can u help? this was the function whose transform i was looking for
<br /> f(x)=\left\{\begin{array}{cc}0,&amp;\mbox{ if }0\leq x\leq \pi/2 \\<br /> cos(t), &amp; \mbox{ if } x&gt;\pi/2 \end{array}\right.<br />
I get the same thing you got. Why would you think the answer should be positive? cos(t) is negative for pi/2<t<3pi/2. If you were trying to transform that step function f(x), where did the cos(t) come from?
well typo on my part , let me edit it,
Here's the culprit :
L \left\{ U_{a}(t) f(t-a) \right\} = e^{-as} F(s)
which implies my result might be wrong
That formula would be helpful for integrating cos(t-pi/2)*exp(-ts) from pi/2 to infinity. But that's not the same as your problem.
So the answers for them would be different?
So the answers for them would be different? As an aside how would you determine L(t^2u(t-1)) with the hint to write t^2u(t-1) in the form f(t-a)u(t-a)
Sure the answers to cos(t)e^(-st) and cos(t-pi/2)*e^(-st) integrated from pi/2 to infinity are different. If you want t^2 to be f(t-1) then I guess f(t) would have to be (t+1)^2, right?
Thats sensible thanks,
