Signals Help Needed: Discrete Time Signal Shifting
  • Thread starter Thread starter magneeto
    Signals
In discrete time signals, shifting a signal x(n-k) to the right occurs when k>0, while x(n+k) shifts to the left. This is because the argument of the function is altered, affecting the timing of the signal's values. For example, in the sine function, shifting the argument left results in the plot shifting right. Similarly, for discrete signals, x(n+1) shifts the plot left by one time unit, as it corresponds to earlier values of n. Understanding this relationship between the argument and the function's plot clarifies the apparent contradiction in shifting directions.
magneeto
signals...help needed
hi,
can anyone tell me why a discrete time signal x(n-k) where k>0 is shifted right along the X-axis(the time domain) and x(n+k) is shifted left. should'nt it be the reverse? this is for the graphical notation. but for the notation x(n)={...,0,3,2,1,0,1,2,3,0,...}
we go left for x(n-k) and go right for x(n+k) which is past samples and future samples respectively. the graphical and short hand notations are really contradictory to me. so pleasezzz help me:rolleyes:
It's the same with continuous-time signals, and maybe a little more intuitive there. The -k or +k changes the argument to the function, so that the y value of the function takes on its value later or earlier than it would without the argument offset.
Take y=sin(x) and y=sin(x-a). Plot y=sin(x) and it crosses the x-axis as usual at x=0 and rising. Now set a=PI/4, so y=sin(x-PI/4). We know that sin()=0 when the argument to the sin() is 0, so sin(x-PI/4)=0 when x-PI/4=0, or x=PI/4. So now the first zero crossing of the plot has shifted to the *right* by PI/4, because the *argument* to the sin() function has been shifted to the left by PI/4. Shifting the argument to the function one way has the effect of shifting the plot of the function the other way.
Hope that helps. It always used to confuse me too, until I understood the difference between shifting the argument and shifting the function. -Mike-
thanks mike. It's easy when u think about the shifting of sine fuctions. But for a discrete time signal x(n+k) means taking future values of x(n) (n is the sampling variable) whereas x(n-k) means taking past values. and when we plot such signals shouldn't it be that for x(n+k) we take the signal to the right and for x(n-k) we take it to the left? if I'm right we can think of n to be equivalent to the time domain. then n+k would go forward in time and this should take the signal to the right! it's still a bit confusing. but it takes the signal to the left :(
No, the same thing applies to discrete signals. Plot some arbitraty y=x(n). Then plot y=x(n+1). The plot shifts to the left by one clock tick, because where n=0 used to give you the first value of y before, now x=-1 gives you the equivalent of the first value. The plot of y=x(n+1) thus looks like the plot of y=x(n), but shifted left in discrete time by one clock tick.
OK :) now it's clear . thank's a lot
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
