Signs of work done and delta K.E.
The discussion focuses on the signs of the answers related to work done and change in kinetic energy in a physics problem. The participant disagrees with the textbook's positive values for the braking force and work done, arguing that both should be negative due to the direction of acceleration and force. They confirm the calculation for distance is correct and matches the expected value. The conversation emphasizes the importance of sign conventions in physics, particularly when dealing with forces and energy. Overall, the consensus is that the answers for work done and change in kinetic energy should reflect negative values.
Ebby
Find the work done by the braking force and the change in kinetic energy of the car.
F = m . a
s = v_final^2 - v_initial^2 / 2 . a
W = F . s
delta K.E. = K.E._final - K.E._initial
I'm asking about this with particular reference to the signs of the answers. Here is the question:
The answers in the back of the book are:
(a) ##1.2 \times 10^4 \text{ N}##
(b) ##39 \text{ m}##
(c) ##4.7 \times 10^5 \text{ J}##
(d) ##4.7 \times 10^5 \text{ J}##
Here's a rough sketch of the situation. I suppose it's not really necessary, but I feel the vectors do emphasise the idea of direction and sign.
I'll now go through each part, with particular attention to the signs of the answers. I have some disagreements with the book, especially regarding parts (c) and (d).
(a) The acceleration ##\vec a## is the negative ##x## direction, so the component ##F_x## must also be negative:$$F_x = m \cdot a_x = 1500 \cdot -8 = -1.2 \times 10^4 \text { N}$$The book has this answer as being positive. I guess what they're really asking for is the magnitude of the force. OK, accepted.
(b) No problems here. ##|\vec s|## and ##s_x## happen to be the same.$$s_x = \frac {{v_x}_f^2 - {v_x}_i^2} {2 \cdot a_x} = \frac {0 - \left( \frac {90} {3.6} \right)^2} {2 \cdot -8} = \frac {-625} {-16} = 39 \text { m}$$
Oops I accidentally pressed post thread. This isn't finished quite yet. How do I delete it?
Ebby said:
Homework Statement: Find the work done by the braking force and the change in kinetic energy of the car.
Relevant Equations: F = m . a
W = F . s
That's what braking force means. The sign is only relevant once you have chosen a coordinate system. You could have the car moving in the negative ##x## direction (or any other direction).
(c) $$W = |\vec F| \, |\vec s| \, \cos \theta = $$
If you were going to say that the answers to parts c) and d) should be negative, then I agree with you. These are negative values regardless of the coordinate system.
Yes that's exactly what I was going to say! Thanks :)
