Electrolysing Sodium Chloride: Silver vs Graphite
  • Thread starter Thread starter Fezziwig
    Electrode Silver
Electrolyzing a hot sodium chloride solution with copper electrodes may lead to the formation of copper chloride, while using graphite electrodes in a cold solution could produce sodium chlorate, which is reactive with organic compounds. The discussion raises concerns about the safety and reactivity of using silver or graphite as electrodes, noting that silver can oxidize to AgCl in chloride solutions and is less noble than platinum. It emphasizes that neither oxygen gas nor sodium chlorate in an aqueous solution poses a fire risk with graphite electrodes, as graphite requires high temperatures to ignite.
Fezziwig
If I was to electrolyse a hot sodium chloride solution I'm pretty sure a copper electrode would react to make copper chloride. Whereas I would have used graphite electrodes if the solution was cold, this reaction should produce sodium chlorate which can obviously be quite reactive with organic compounds. The only other thing I have in the house is some spare silver. It's no platinum but it is more inert than copper. Would silver or graphite be safe, or should I only attempt this with platinum?
Chemistry news on Phys.org
Silver is not that noble, especially in the chlorides solution it can be relatively easy oxidized to AgCl.
What are you actually trying to do here?
Neither the oxygen gas nor sodium chlorate in aqueous solution, even at 100 degrees, should start a fire with your graphite electrode. Graphite requires very high temperatures to ignite.
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
