Simple 4th grade question I presume
  • Thread starter Thread starter ph123
To find the values of two masses given their ratio (m1/m2 = 0.7941) and their sum (m1 + m2 = 13 kg), start by expressing one mass in terms of the other using the ratio. Set m1 = 0.7941 * m2, then substitute this into the sum equation to create a single-variable equation. Solve for one mass, then use that value to find the other mass. This method effectively utilizes two equations to solve for two unknowns. Mastering this approach is essential for solving similar problems in the future.
ph123
Does anyone know (I know I should) how to find the value of two masses when you have:
the ratio of masses (m1/m2)
and
the sum of the masses (m1 + m2)
m1/m2 = 0.7941
m1+m2 = 13 kg
My first thought was m1/m2 * m1 + m2 = 10.3233 = m2
Clearly not right though as the ratio of m1 to that is not the ratio I found.
From your ratio you can say m1=0.7941*m2.
You have 2 equations and 2 unknowns. Pick one equation and solve for one of the variables. Then plug this into the second equation so that you have everything in terms of the one variable. Then you can solve for it and plug into the original equation to find the second unknown. If youre in 4th grade, get used to this, because youll come across it a lot
