Simple application of Derivitives problem
  • Thread starter Thread starter Leonidas
    Application
To find two positive numbers whose product is 192 and whose sum is minimized, the equations x*y=192 and y=192/x are established. The derivative dy/dx is calculated as -192/x^2, leading to confusion about setting the derivative to zero for local extrema. The correct approach involves minimizing the function x + 192/x instead. The discussion highlights the realization that the sum can be minimized by correctly applying calculus principles. Understanding this method clarifies the problem-solving process.
Leonidas
Find two positive numbers that satisfy the given requirements.
The Product is 192 and the sum is a minimum.
I said that x*y=192 and y=192/x and that dy/dx= -192/x^2
I thought that we were supposed to set the derivitive equal to zero in order to find the local extrema... however -192/x^2 does not equal 0...right?
I'm dazed and confused... can someone please help?
You should have done
xy = 192
y = \frac{192}{x}
x + y = (number)
Minimize this:
x + \frac{192}{x} = (number)
oh.
1. That was really fast... thanks.
2. I should have seen that.
3. :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
