DIY Scooter Voltage Regulator and Rectifier Circuit Help - New User"
  • Thread starter Thread starter dutsidoo
    Circuit
The user is attempting to create a voltage regulator and rectifier circuit for a scooter to charge the battery while driving, using a 70 VAC output from the stator. They have constructed a bridge rectifier with diodes, a resistor, and a capacitor, and are using a Zener diode to regulate the output to 13.6 VDC. Although the circuit works well on a bench test with 120 VAC, it fails to provide sufficient current to light a 12 VDC bulb. Other users suggest that the 70 VAC may be a specialized winding and recommend checking for a dedicated 12 VDC output from the scooter's alternator that can provide adequate current for battery charging. The discussion emphasizes the need to verify the scooter's electrical system for proper functionality.
dutsidoo
OK, New to this site. here is my task at hand.
I am trying to make a votage regulator and Rectifier for my scooter to charge the battery while driving it.
I have about 70 VAC coming from my stator (not really sure what the amp out is). I have made a bridge rectifier using (4) diodes. I put a 10K ohm resistor across the bridge as well as a 100 Volt 500 mf capacitor on the out side of the rectifier.
I then am using a 5 watt 13.6 Zener diode to drop it to 13.6 VDC. On the bench (plugging it into 120VAC) this works great and I get 13.6 volts DC out of the circuit. But not even enough juice to light a 12 VDC light bulb. I'm trying to charge my battery with this circuit, but have very little current.
What am I missing?? Any help or a circuit drawing would be much appreciated.
Thanks much
Are you using the alternator that came with the scooter? I would expect that to put out 12VDC, just as in a car. The primary purpose is battery charging.
I suspect that the 70VAC you found is a specialized secondary winding for special purposes, and that there is another 12VDC output with enough amps to charge the battery. Look again.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
