Simple current limiter for LTSpice
  • Thread starter Thread starter tfr000
    Current Ltspice
The discussion revolves around creating a simple current limiter circuit in LTSpice, focusing on how to limit the current from a voltage source to a specified maximum value. Participants explore various circuit designs and approaches, including both theoretical and practical implementations.
  • One participant seeks a simple method to limit current from a voltage source in LTSpice, describing the desired behavior akin to a lab power supply.
  • Another participant suggests a link to a resource that may provide relevant circuit ideas, although they express frustration over the scarcity of information on this topic.
  • A participant unfamiliar with LTSpice offers a high-level approach involving voltage-dependent sources and current sensing, but admits uncertainty about a straightforward solution.
  • One participant proposes using a transistor current limit circuit as a potential solution.
  • Another participant describes a method involving an ideal diode to limit current sourced and sunk, emphasizing the effectiveness of this approach.
  • A participant shares a custom symbol and sub-circuit for a current limiter device, detailing how to integrate it into LTSpice.
  • One participant mentions the use of an "arbitrary behavioral voltage source" as a way to achieve the desired current limiting behavior without designing a full circuit.
  • A participant expresses appreciation for the proposed solution and acknowledges a misunderstanding regarding the use of certain LTSpice components.
  • Another participant shares a custom implementation of a current-limited voltage source in a different SPICE environment, providing a mathematical expression for its behavior.
There is no clear consensus on a single solution, as participants propose multiple approaches and express varying levels of familiarity with LTSpice. Some solutions are appreciated, while others remain untested or unclear.
Participants express uncertainty regarding the effectiveness of certain components and methods in LTSpice, indicating that some proposed solutions may require further testing or clarification.
tfr000
Looking for a simple way to limit the current from a voltage source in LTSpice. Not a realistic or practical circuit, just something that will give me the behavior that I want. Hitting a total mental block with this, for some reason.
What I want is for the source to act normally until the connected circuit draws more than X current - at which point it supplies X current and no more. Like a lab power supply.
I am not an LTSpice user, so my help is only high level. I don't know of a simple way to do it.
1. Use a voltage dependent voltage source as the main source.
2. Monitor the current with a current dependent voltage source.
3. Reduce the source voltage (in 1 above) when the current sensed by 2 goes above a certain level. (requires a control amplifier with a reference reference and some sort of output clamping)
(note than an opamp is basically a voltage dependent voltage source with high gain)
Perhaps an Arbitrary behavioral voltage source could provide clamping in the control amp.
http://ltwiki.org/?title=B_sources_(complete_reference)
There is probably some neat trick to do this, but I don't know it. Spice has a table driven source that can supposedly do it, but I don't see it in LTSpice
Can you just use a simple transistor current limit circuit like this?
http://forums.parallax.com/uploads/attachments/58478/86715.gif
Good simple circuit.
Seems like there should be a cool way to build a simple version of that with ideal sources. Q1 as a VDVS and R/ Q2 as a CDVS.
Ok, so here's what I dreamed up...
In the first, a current-controlled voltage source (an "H" source) is tied to a typical small-resistance current sensor. This one can be adjusted in various ways by messing around with the various parameters, for instance, to get a "soft" current limit.
In the second, you get a hard current limit from an ideal current source, and a hard voltage limit from an ideal zener
The trick is very simple and effective, adding an ideal diode to any voltage source with the Ilimit parameter set (along with Ron=0 for perfect ideal behavior) will limit the current sourced to the specified value.
To also limit the current sink add another diode in parallel but reversed.
The diode model takes care of smoothing the discontinuity when switching between regions so that the simulation converges properly.
I have added a symbol and corresponding sub-circuit so that the current limiter device ilim can be selected from the components list and configured through the right click menu.
Rename file ilim_asy.txt to ilim.asy and ilim_cir.txt to ilim.cir and drop in the directory where you store your local components (or the LTspice library dir) and make sure that directory can be selected from within the component window.
After adding the component, in the right click configuration pane along with the current limit, optional series resistance and fixed voltage drop can be also specified (just added some random V and R numbers here, R and V are zero for the plot showed below).
I use these for instance to model AVR microntroller pins which are current limited at 40mA and with approximately 30Ω of (MOSFET) Ron.
The plot below shows the current limit in both directions in explicit action ...
Pasqo, that worked great for me. Thank you Sir!
The way to do this in LTSpice is with an "arbitrary behavioral voltage source" (type in "behavioral" in LTSpice help/search).
This save you from having to design an actual circuit that creates this behavior (which may not be ideal). Instead, simply describe the behavior you want mathematically.
http://www.linear.com/solutions/6106
the_emi_guy,
how do you do it then? i was playing around with bi and bv sources, but don't see any options to limit current.
Unless you know of some trick with one of ltspice's math functions, i think Pasqo's solution is quite elegant and the best.
Regards
Thanks Pasqo!
Erik Haverkamp said:
Thanks Pasqo!
Agreed! Great solution. My initial impression was that this could be done with bi, bv but I think I was wrong.
How do I actually use this component?
I've just connected a capacitor to it and added the GND port.
However, all simulations show a flat line when I plot them.
Cheers Timur
Welcome to PF.
Attach to a post your circuit.asc but add a .txt suffix to make circuit.asc.txt
We can then run your design and work out what is missing.
Sorry guys beginner mistake the post from pasko from the Feb 17, 2016.
Has actually a circuit which I didn't not pay attention to. Anyway in the circuit I uploaded I did not have V source. Because I thought this is done by the Imilit source
Hi,
I have developed a one-line current limited voltage source. It works in the NI Multisim SPICE environment which uses the SPICE 3:
Bx 1 2 V= { G * V(3, 4) * (Abs(I(Bx)) < Imax ? 1 : 1 - (Abs(I(Bx))/Imax - 1)/k) }
where
  • Bx the name of the new B-type component
  • 1, 2 the output pins
  • 3, 4 the input pins (it controls the voltage between 1 and 2)
  • G is the gain from V(3, 4) to V(1, 2)
  • Imax is the maximal output current (in Ampere)
  • k is a <1 factor which controls the degradation speed of output voltage over the Imax limit (e.g. k=0.2 means that between Imax and 1.2 * Imax the output voltage will linearly goes to zero)
I hope it will be useful for you.
I present you a Multsim simulation result of running a test circuit for the component above (the input and output signals are shifted down and up):
  • · Replies 19 ·
  • · Replies 23 ·
