Simple faraday's law problem (phi = what?)
The discussion revolves around calculating the induced electromotive force (emf) in a circular loop of wire surrounding a toroid with sinusoidal current. The magnetic field inside the toroid is derived using Ampère's Law, leading to the expression for B. A key point of contention is whether to use the cross-sectional area of the toroid or the area of the larger loop for calculating the flux. It is clarified that the relevant area for flux is indeed the toroid's cross-section, as the magnetic field is not uniform across the larger loop. The conversation concludes that the original approach is close to correct, especially given the condition that x is much smaller than R.
darksyesider
A toroid with N windings and radius R has cross sectional radius x (x<<R).
The current running through the wires is given by ##I = I_0\sin (\omega t)##.
There is a magnetic field in the center of the toroid.
A loop of wire of radius three times that of the toroid is placed around the cross section of the toroid
(like http://s3.amazonaws.com/answer-board-image/9fa3691b-46c6-4de7-b608-82705d9efa60.gif, but it's circular, not a rectangle).
Find the induced emf in the circular loop of wire.
E = -dphi/dt
##\int B\cdot ds = \mu_0 I\implies B(2\pi R) = N\mu_0 I \implies B = \dfrac{\mu_0 N (I_0\sin\omega t)}{2\pi R}## (*)
then ##\mathcal{E} = \dfrac{- d\phi}{dt} = - \dfrac{d(BA)}{dt} = -\pi x^2 \dfrac{dB}{dt}##, where dB/dt is just the derivative of (*).
My question is, that should it be ##-\pi x^2## (the cross section of the toroid) or should it be the area of the loop ( pi*(3x)^2) ?
My reasoning for pi*x^2 is that since there is no flux at parts of the circular loop, it's just the area of the cross section (no flux since no magnetic field!).
You need to integrate B across the toroid's cross-section to the the total flux. B is a function of the radial distance from the toroid's center (not the cross-section center; I mean the center of the hole). You have oversimplified the problem by using the value of B at the outermost radial distance R.
EDIT: I don't see why that is true, isn't R fixed?
Sure is, but the B field isn't confined to r = R.
can you specify where it is incorrect? I still don't see what you are referring to.
As I said, you have determined the B field for r=R but have done nothing to determine what it is for r<R. R is the OUTER radius of the toroid. Ir also has an inner radius, which is R-2x. So we have R-2x < r < R.
B is a function of the radius r: B = B(r). You have computed B(R) only. Figure out why B(r) > B(R), r < R, just the way you found B(R).
Is there an elementary way to solve this then? (AP Physics C level)?
If the cross section was a square, it would be easy, but here it's harder.
In either case it requires integrating strips of the cross-section, from r = R-2x to r=R, to get the total flux which is what you need.
EDIT: ON SECOND THOUGHTS, since you were given x << R your original post solution is close to correct and probably what was intended.
I don't understand how you came up with your alternative area pi(3x)^2. What has a radius 3x?
The larger loop of wire.
Oh, right. But the area you want is, as you said, where the flux is, which is in the toroid cross-section only. Good work and sorry if I sidetracked you. If R >> x had not been given you would have had to integrate.
