Simple harmonic motion of a machine part
A machine part undergoing simple harmonic motion (SHM) with a frequency of 5 Hz and an amplitude of 1.80 cm is analyzed to determine the time taken to move from x = 0 to -1.80 cm. The angular velocity is calculated as 31.41 rad/s, and the displacement at -1.80 cm corresponds to the negative amplitude. By sketching the displacement versus time, it is noted that the time to reach -1.80 cm is a fraction of the period, which is 0.2 seconds. The calculated time is 0.05 seconds, but there are two valid answers for this question. Understanding the periodic nature of SHM is crucial for solving similar problems.
kaywond
A machine part is undergoing SHM with a frequency of of 5hz and amplitude of 1.80cm. How long does it take the part to go from x = 0 to -1.80cm?
x = Acoswt
X is given and convert it to metres 0.018. I need to manipulate answer to get time.
angular velocity is 2pi x 5 = 31.41. It is just an equation manipulation. could someone please show me the technique?
The displacement is the negative of the amplitude.
If the peak amplitude is 1.8cm then asking when the displacement is -1.8 makes it rather easy. No need to even use the sin button on the calculator :-)
Sketch displacement vs time. Mark the points 1.8m and -1.8m. If T is the period (=1/5) at what fraction of T does 1.8cm and -1.8cm occur?
thanks 1/5 equals 0.2. Then divide by 4 and 0.05 is the time in seconds
0.05s is one valid answer but there are two possible valid right answers for this question. I recommend you give both.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
