Simple Harmonic Motion Pendulum, can we use PE=1/2kAmplitude^2?
The discussion centers on the applicability of the formula Potential Energy = 1/2K(A^2) for a pendulum, particularly when only the angle of displacement is provided. It is clarified that this formula is not suitable for pendulums since it involves a spring constant (k), which does not apply in this context. Instead, the gravitational potential energy of a pendulum bob should be calculated using the formula mgh, where h is the height relative to the lowest point. The relationship between height and horizontal displacement is established using Pythagorean theorem, leading to an effective spring constant defined as mg/L. Overall, the correct approach for pendulum potential energy involves gravitational principles rather than spring mechanics.
hongiddong
I was wondering if we can somehow use the formula Potential Energy = 1/2K(x(x=Amplitude))^2 for a pendulum if we are only given the angle of displacement?
Would the problems normally just say the PE at the top of the pendulum is such and such, please find max Velocity,
Or also the max velocity is such and such please find max potential energy, or max amplitude.
Your formula for potential energy is not the one usually given in descriptions of a harmonic oscillator, and it is generally unclear what you are asking about. Being more specific could help.
No, you can't. ##k## is the spring constant. There is no spring involved with a pendulum.
Likes 1 person
The k in Hong's formula is an equivalent spring constant. The gravitational PE of the pendulum bob relative to its lowest position is, mgh, in which h is its height relative to its lowest point. It's easy to show by Pythagoras that for small displacements with horizontal component x, for a pendulum of length L, x^2 = 2hL. So the PE of the bob is mgh = \frac{1}{2} \frac{mg}{L} x^2, so the effective spring constant, k, is \frac{mg}{L}.
Likes 1 person
Thanks Everyone!
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
