Archived Simple Harmonic Motion - Spring-Pendulum-Mass System
The discussion focuses on deriving the period of a spring-pendulum-mass system for small amplitude vibrations. Participants highlight the importance of understanding the forces acting on the bob and suggest using energy principles to approach the problem. The equations for simple harmonic motion related to springs and pendulums are referenced, emphasizing the need to combine these concepts. Members are encouraged to collaborate and share solutions, as the original poster may not respond due to the age of the thread. Overall, the thread serves as a resource for tackling the oscillation characteristics of the system.
cpin11
A pendulum of length L with a bob of mass M hangs vertically. The bob is attached to a horizontal spring that has a force constant k. When the bob is directly below the pendulum support, the spring is unstretched. (a) Derive an expression for the period of the oscillating system for small amplitude vibrations.
x = Acos(wt)
w = 2pi/ T
E = 1/2 k A^2
w = sqrt (k/m) for a spring
w = sqrt (g/ L) for a pendulum
I'm pretty sure I need to use energy for this problem but I'm having trouble understanding the system itself.
Draw a picture if it helps.
Since you're given the force constant for the spring it might be easier to consider the forces on the bob.
From the READ ME pinned thread for this forum:
Greg Bernhardt said:
Members are free to work on these older homework threads. Know that none of these problems are relevant to the OP because of their age. So it's best not to ask the OP questions because they likely won't respond, but they may. The point is that you should work with what you are provided to solve the problems without the OP's input. Members are encouraged to collaborate with others within the thread. Creative and alternate methods are also encouraged. Full solutions are acceptable.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
