Simple Harmonic Motion of a particle
danago
A particle moves in a straight line so that its position, x cm, from a fixed point O, at time t seconds is given by x=3+12sin(2\pi t)+5cos(2 \pi t).
Prove that the particle is undergoing simple harmonic motion, and find x when its speed is 26\pi cm/s.
I was fine with the first part of the question...
<br /> \begin{array}{l}<br /> x = 3 + 12\sin (2\pi t) + 5\cos (2\pi t) \\ <br /> v = \dot x = 24\pi \cos (2\pi t) - 10\pi \sin (2\pi t) \\ <br /> a = \ddot x = - 48\pi ^2 \sin (2\pi t) - 20\pi ^2 \cos (2\pi t) = - 4\pi ^2 (x - 3) = 12\pi ^2 - 4\pi ^2 x \\ <br /> \end{array}<br />
With the second part, i can easily set the velocity equal to 26\pi and solve it on my calculator, but how can i solve it algebraically?
Thanks in advance,
Dan.
If you want to solve it exactly, you can write an expression of the form A*sin(x)+B*cos(x) as a single trig function. See the wikipedia page of trig identities under 'Linear combinations'.
Algebraically, the equation simplifies to x=3+13sin(2\pi t+\theta) where \theta=sin^{-1}\frac{5}{13}.
Ah ofcourse, i forgot about solving it like that. Thanks :smile:
I have a wooden log floating in the water and it is being pushed towards the water. I am to show that the force that is pushing the log back to the equilibrium position is harmonic, and i just have no idea how to do it... There are no equations attached.
If you have a question, don't piggy-back it on someone else's thread. It won't get the notice it deserves. You don't need to show the 'force is harmonic', to show something is a harmonic oscillator you just need to show the restoring force is proportional to displacement. If this isn't clear, DON'T REPLY HERE. Start a new thread.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
