Wolftacular
- 6
Three cables are used to tie the balloon shown in the figure. Determine the vertical component of the force P exerted over the balloon at point A, if the tension on cable AB is 259 N.
http://img521.imageshack.us/img521/9687/physicsballoonproblem.png
(Sorry for the figure. I had to re-draw it myself, on paint, with a touch pad. Assume all measurements are parallel to the axises, of course)
Pythagorean theorem.
Figured out the resulting distance of AB with Pythagorean theorem and then used cross multiplying to find out the equivalent vertical component of AB. Then...
What I did: Simply multiplied that resulting vertical force (207.2 N) times three for each of the cables, for a vertical resultant of 621.6 N.
What the teacher did: He also found the x component of AB and equaled it to the x component of CA, found the z component and equaled it to that of AD. Then, with lots of triangle solving, found the three different y components and added them all up for a result of 1000-something N.
MY QUESTION:
How would you go about solving this problem? The teacher reasoned that the x and z components had to be in equilibrium to find the y resultant. I disagree because he never stated that the balloon was in equilibrium anywhere. Is he wrong? Or should I always assume that, when finding a component, all other components should be balanced?
This is a test question and he's very stubborn so I want to know what you all think.
