Simple question about current draw
  • Thread starter Thread starter kickflipper11
    Current
The discussion centers on the application of Ohm's Law in understanding current draw in electrical circuits, particularly when comparing resistors and motors. A circuit powered by 10V with a 1 Ohm resistor will draw 10A, but when using a motor, the resistance changes, affecting current flow. Larger motors require more current to operate, which can lead to confusion regarding their resistance compared to smaller motors. It's clarified that a higher power motor at the same voltage will have lower resistance, while a lower power motor will have higher resistance. Understanding these relationships helps in grasping how power supplies must be capable of providing the necessary current for different loads.
kickflipper11
Hello,
I've been working with some electrical stuff at my internship lately, but I don't have any real background in it, so I've been trying to learn what I can from the internet. One thing that I don't get involves Ohms law:
If I have a circuit powered by 10V with just a 1 Ohm resistor, the current flow will be 10A (I think). If that resistor is replaced by a motor, which would have a much larger resistance, the current flow will drop according to I=V/R. But common sense tells me that a larger motor would need more current for it to run. I'm sure I'm confusing the concepts. Basically, I can't mesh the idea that current draw will be higher to power larger motors and the idea that I=V/R.
I hope that makes sense, any response would really be appreciated, thanks!
I guess I'm not really clear what your issue is. Ohms law is it.
If you maintain a 10v supply (capable of supplying whatever current is needed) and you have a 1 ohm resister load then you get 1 amp of current and if you increase the resistance then you get less current and if you decrease the resistance you get more current.
A 10V DC motor generating 100Watts would need 10 amps (and so by implication would have a 1/10 ohm resistance.
It is possible to have a DC power supply that generates 1am with no problem but just can't hack 10amps, so with a given input voltage, stronger motors require a power supply that can drive more load.
In a theoretical diagram this is the case.
In a real world application a voltage source will have a current supply limit. If you find a lab power supply, most of them have the ability to be current limited, so if you set the limit to 1A and then tried to put 10V across a 1R resister, the supply would hit 1A and the voltage will drop back according to Ohms Law to 1V.
Thanks a lot, that actually did answer my poorly phrased question. I had it in my head that a larger motor that had a higher rated power must have a higher resistance than a lower power motor, which was why I was confused because that wouldn't make sense with Ohm's Law. I didn't realize that a lower power motor would have a higher resistance. So a:
10 V, 100 W motor needs 10A and has 1 Ohm of resistance
while at 10 V, a 10 W motor needs 1 A and is 10 Ohms?
you got it
Ok, I'm glad you cleared that up, thanks a lot it was really buggin me.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
