Calculating Wavelength with Wave Speed and Period | Physics Homework Help
  • Thread starter Thread starter bfitzp
    Wavelength
To calculate the wavelength of a wave with a speed of 160 m/s and a period of 4.9 ms, the formula λ = vT is used. The initial calculation resulted in λ = 160 m/s x 4.9 ms, yielding 784m. However, the period must be converted to seconds for proper unit consistency, as 4.9 ms equals 0.0049 seconds. After correcting the calculation to λ = 160 m/s x 0.0049 s, the correct wavelength is found to be 0.784 m. Ensuring unit conversions are properly applied is crucial for accurate results.
bfitzp
What is the wavelength λ of a wave that has a speed of 160 m/s and a period of 4.9 ms?
λ = vT
λ = 160 x 4.9
= 784m
However this answer is showing up as inccorect when I submit it online. What am I doing wrong?
what is the answer?
You should check the units of what you computed.
The units are metres. Cant see why 784m is being marked as incorrect.
They're not metres and that's your problem. Go back and do the calculation again, but include the units and any conversions that you need to do.
Ah yes, don't know how I missed that. Cheers mate.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
