Simple question regarding the Ah rating of a battery
  • Thread starter Thread starter motivehunter
    Battery Rating
A 12V 7.2 Ah sealed lead-acid (SLA) battery is expected to discharge 7.2 amps for one hour, but in practice, it typically lasts around 45 minutes. When demanding a current of 20A, the battery may only deliver usable power for approximately 6 to 10 minutes due to voltage sag. The relationship between current draw and discharge time is not strictly linear, as higher currents significantly reduce the effective capacity. Additionally, the battery's age can further impact its performance and discharge duration. Understanding these limitations is crucial for applications requiring consistent power delivery.
motivehunter
Hi all!
Excuse the simple nature of this question, but I'm a mechanical engineer working on building his own PAS bicycle and need to understand this to go ahead with my work.
I understand that a 12V 7.2 Ah battery ideally discharges 7.2 ampere of current at a nominal voltage of 12V for 1 hour. But in reality, it is only capable of doing this for 45 minutes.
So am I correct in assuming that as the battery is an SLA (sealed lead-acid), if the application demands 20A, it will deliver the current at nominal voltage for 16.2 minutes? I mean, is this relationship linear?
Thanks in advance!
The concept of ampere-hours does lead you to expect that. But in practice, the heavier the current, the less realistic that is. From a 7.2AH battery you may get only 6 to 10 minutes at 20A before the voltage sags too low to be useful.
Thank you so much!
In theory its linear yes, again just like NascentOxygen said it will drop too much after 10 minutes which makes it useless. If the manufacturer says it discharges that in 1 hour in practice you need to consider less than that, probably even less than 45 mins. It also depends on the battery's age.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
