Negative Magnitude Phasor Presentation: Is Erasing the - Sign Correct?
When dealing with a phasor that has a negative magnitude, the correct presentation involves erasing the negative sign and adjusting the phase angle by adding or subtracting 180 degrees. The resultant phase angle should be kept within the range of +/-180 degrees or converted to a 0 to 360-degree format as needed. Modulo arithmetic may be necessary in certain cases to maintain this range. This approach ensures clarity and accuracy in phasor representation. Proper handling of negative magnitudes is essential for effective analysis in electrical engineering contexts.
fbenit1
If you have a phasor that has a negative magnitude (ie -3<38degrees) what is the best presentation. I believed it was just erasing the - sign and adding or subtracting 180degrees. Correct me if wrong
That's right - just remember the resultant phase angle would lie between +/-180 degrees (or 0 and 360, if that's the way you want to do it) - so you may need to do some modulo arithmetic in some cases.
you are right
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
