Understanding Alkenes & Alkynes: Bromine Water Test
  • Thread starter Thread starter Bladibla
    Test Water
To distinguish between alkenes and alkynes, bromination can be employed as a key method. When reacting with excess bromine (Br2), alkenes will undergo dibromination, adding two bromine atoms, while alkynes will undergo tetrabromination, adding four bromine atoms. This difference can be confirmed by measuring the mass of the product or using spectroscopy techniques. Additionally, infrared (IR) spectroscopy can be useful, as the stretching frequencies for alkynes and alkenes differ significantly. Nuclear magnetic resonance (NMR) spectroscopy can also provide identification through distinct splitting patterns associated with each type of compound.
Bladibla
Hey all
How do you distinguish between and Alkene and Alkyne?
Bromine water is discoloured in both, so that rules out BW.
Chemistry news on Phys.org
you could try to take the compound and try to brominate the bond twice. excess Br2+alkyne---> tetrabromination excess Br2+alkene----->dibromination. So if your compound is an alkyne you can add on 4 bromines, if it is an alkene you can add on 2 bromines. After you are done reacting you can figure out how many bromines were added by finding mass or doing spectroscopy thus you can figure out if the compound is an alkyne or alkene
How about just getting an IR spectrum? If the alkyne isn't symmetrical, that is.
The alkyne stretching frequency should be significantly different from the alkene stretching frequency.
NMR would tell you what your compound is as well, you would just have to look for different splitting patters.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
