Troubleshooting a Simple Sun Tracking Device: Tips and Solutions
The discussion centers on troubleshooting a simple sun tracking device that uses two photovoltaic cells to control a DC motor. The initial testing with a torch was successful, but sunlight does not produce the expected response, likely due to insufficient signal difference between the cells. Suggestions include adding a shade to create a more pronounced angle of incidence or using a tube to focus sunlight on the cells. Additional considerations involve ensuring the cells are properly oriented and accounting for overnight positioning errors. The conversation emphasizes the need for adjustments to improve the device's responsiveness to sunlight.
tina-duncan
Hi friends!
I have recently started a small project where I had hoped to build a simple sun tracker.
My initial plan involved 2 Photovoltaic cells mounted at either end of a panel which was attached to a shaft which was then attached to a small DC motor. Both cells were hooked to the motor and initial testing with a small torch was successful; when light hit the left cell the motor would rotate clockwise and vice versa for the right cell.
My problem arises when i attempt this using sunlight, put simply nothing happens, my guess is that there simply is not enough of a discrepancy between the cells to cause an effect.
So my question, is there a way I can alter the system or add some sort of component in some way to fix this problem?
Thanks,
Tina D :)
Without seeing the whole setup I think you are probably right about not getting enough signal difference. You could try putting some kind of shade over the photocells such that the sun has to hit the cell at a slight angle before it does anything. Or maybe a tube aimed at the sun which limits the angle of incidence.
Are you talking about longitude (time of day, East-West) tracking? Are the two photocells directly facing the sun, or are they partially shadowed by the edges of the panel or baffles so that a panel East West pointing error causes a change in the sunlight hitting each photocell? Does your setup account for overnight (sundown-to-sunrise) pointing error? Please post a sketch of setup if possible.
Bob S
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
