Simple superconductor question
In summary, a simple superconductor is a material that can conduct electricity with zero resistance at extremely low temperatures. It works by allowing electrons to flow through the material without encountering any resistance, and has applications in MRI machines, particle accelerators, and high-speed trains. However, it requires cryogenic cooling and has limited commercial applications due to its low operating temperatures.
sniffer
112
suppose we have a superconductor speciment above Tc, and we put it in magnetic field. then we cool it down to below Tc, then a screening current is produced.
where does the electron get the energy to initiate the current on the first time?
Magnetic field. If not, then the energy it gets is from the energy you used to cool it down.
The energy for initiating the screening current in a superconductor comes from the external magnetic field. When the superconductor is above its critical temperature (Tc), it does not have perfect conductivity and can allow some magnetic flux to pass through it. However, as the temperature drops below Tc, the superconductor's conductivity increases significantly and it starts to expel the magnetic field, generating a screening current to cancel out the external field. This process is possible due to the formation of Cooper pairs, which are pairs of electrons that can move through the lattice without resistance. Therefore, the energy for initiating the screening current comes from the external field, but it is sustained by the superconductor's unique properties and the Cooper pairs.
1. What is a simple superconductor?
A simple superconductor is a material that can conduct electricity with zero resistance at extremely low temperatures.
2. How does a simple superconductor work?
A simple superconductor works by allowing electrons to flow through the material without encountering any resistance, due to a phenomenon called Cooper pairing.
3. What are the applications of simple superconductors?
Simple superconductors have a wide range of applications, including in MRI machines, particle accelerators, and high-speed trains.
4. Can simple superconductors be used at room temperature?
No, simple superconductors require extremely low temperatures (usually below -200 degrees Celsius) to exhibit their superconducting properties.
5. Are there any disadvantages of using simple superconductors?
One disadvantage of simple superconductors is their requirement for cryogenic cooling, which can be expensive and energy-intensive. They also have limited commercial applications due to their low operating temperatures.
  • Other Physics Topics
  • Atomic and Condensed Matter
  • General Discussion
  • Electromagnetism
