Simple trig which I have forgotten
  • Thread starter Thread starter NOP90
    Trig
The discussion centers on calculating the height of a small ball attached to a 0.33m string, displaced 60 degrees from the vertical. Participants clarify the importance of using the correct string length and trigonometric functions to find the height. The calculations involve using cosine to determine the vertical position of the ball relative to its lowest point. There is confusion about the representation of coordinates in the calculations, which is clarified as x and y values. Visual aids, such as drawing a diagram, are recommended to better understand the problem.
NOP90
Small ball fastened to a piece of string 0.33m in length. The ball is displaced by 60 degrees from the vertical. What is the height of the ball at this point?
sin? cos? tan?
This is part of a bigger physics question in which I need to work out potential energy (mass*9.8*height). I have forgotten my basic trigonometry :blushing: and need help finding out the height.
sin? cos? tan?
Is the string 1/3 m or .33m? If it's given as 1/3 m. don't use such a crude approximation as .33m. If it's given as .33 m, then you're OK.
An equivalent problem is this: Pull the ball to the right so that the string is horizontal. Swing the ball down by 30 degrees. If the string's length is r meters, and the string is fastened at the origin (0, 0), the position of the ball will be (r cos(-30 deg.), r sin(-30 deg.)) = (r sqrt(3)/2, -r/2). All you have to do is figure out how high this point is above the low point when the ball is hanging straight down.
Sorry mate, it's 0.33m, originally 330mm but I am working in SI units.
I'm a bit confused with that. So the length of string is 0.33m. Do I calculate 0.33*cos(-30deg.)? What does the comma between rcos(-30deg.) and rsin(-30deg) represent? Do I use both calculations? Do I also calculate what is on the right of the = ?
Yes, r = .33. The comma between rcos(-30deg.) and rsin(-30deg) is there because these are the x and y coordinates of a point.
Draw a picture...
