Is 2tan2b the Simplified Form of tan(45° + b) - tan(45° - b)?
  • Thread starter Thread starter philipp2020
The discussion focuses on the simplification of the expression tan(45° + b) - tan(45° - b). The initial attempt led to confusion regarding the correct numerator, which was clarified to be just 4 tan b, rather than including an additional 1. The correct denominator was acknowledged as valid, and it was noted that this simplification leads to the final result of 2 * tan 2b. The conversation emphasizes the importance of accurately applying tangent sum and difference identities for proper simplification. The conclusion confirms that the simplified form is indeed 2tan2b.
philipp2020
hi
i have a question on a simplification
tan (45° + b) - tan (45° -b)
Then I put on both sides the Theorems for Addition. But I am not sure if my result is right. What is most possible simplification here?
is it 1 + 4 tan b / 1 - tan^2 b ?
Thanks very much for an answer.
Greetings
Philipp
Double check the tangent sum and difference identities. Your denominator is good, but I can't figure out what mistake you could have made to get the numerator that you did.
If you get the numerator correct, there's another identity that allows you to simplify the fraction.
ah so the numerator is only 4 tan b and not plus 1 yes...
oh ok... i see
then at the end it will be just 2 * tan 2b
