Simplifying boolean expressions
The discussion focuses on simplifying two complex boolean expressions. The first expression, (A + B)(A' + B + C)(A' + B + C'), is analyzed and ultimately shown to simplify to B, not 1, despite initial confusion. The second expression, A + ABC + A'BC + A'B + DA + DA', is simplified to A + A'B + D, which is confirmed as its simplest form. Participants emphasize the importance of using truth tables and careful simplification techniques to verify results. The conversation highlights common pitfalls in boolean algebra and the necessity for methodical approaches to achieve accurate simplifications.
magnifik
i have two boolean expressions that I'm simply stuck on. (any variable with the ' mark means NOT). i used http://hopper.unco.edu/KARNAUGH1.1/Function.html" to check my answers for both..apparently they are both supposed to equal 1. i have tried solving the expressions multiple times, and each time i try i get stuck
= AA' + AB + AC + A'B + BB + BC(A' + B + C')
= AB + AC + A'B + B + BC(A' + B + C')
= B(A + A') + AC + B + BC(A' + B + C')
= B + AC + B + BC(A' + B + C')
= (B + AC + BC)(A' + B + C')
= A'B + BB + BC' + A'AC + BAC + ACC' + A'BC + BBC + BCC'
= A'B + B + BC' + ABC + A'BC + BBC
= A'B + B + BC' + ABC + A'BC + BC
= A'B + B + BC(A + A') + B(C + C')
= A'B + B + BC + B
= B(A' + 1 + C + 1)
= B(A' + C + 1) = A'B + BC + B
need help after this
= A + BC(A + A') + A'B + D(A + A') by distributive property
= A + BC + A'B + D by complement (A + A' = 1)
i don't know what to do after this...
For the first one (assuming all your math is correct), keep in mind that from the truth table for an OR, 'X OR 1 = 1' (where X = anything), hence if you had BC + B = B(C+1), C OR 1 = 1, hence BC + B = 1B = B (since 1 AND X = X). You could extend this to say that B(A'+C+1) is comprised of A'+C being the aforementioned 'anything' and thus (A'+C) + 1 = 1, so you are left with B ... which is not 1.
*For the second one, what do you get if you simplify (A+ABC) and (A'BC + A'B) and (DA+DA') instead of the choices you made?
If you use that website, be a little careful.
I put (A + B)(A' + B + C)(A' + B + C') (original equation) in and it said the answer was 1.
I put (A + B)(A' + B + C) in and it said the answer was 1.
I expanded this out to AA'+AB+AC+A'B+BB+BC and it said the answer was A'+B+C.
I simplified this to AB+AC+A'B+B+BC and it said the answer was A'+B+C.
I simplified this to AC + B(A+A'+1+C) and it said the answer was 1.
I simplified this to AC + B and it said the answer was A'+B+C.
I put in A+B and it said the answer was 1.
I put in A+B+C and it said the answer was 1.
Hopefully by now you can see the pattern ... its gone bonkers and shouldn't be trusted.
I went over your first equation and did my own version and I agree with your result.
Is this what you have to simplify ?
If so, you can solve it mentally.
Try to spot in the formula some regularity, some "weakness".
I will go on with the solution in the spoiler, if you want to work it yourself, don't open it.
Notice (A' + B + C)(A' + B + C')
let's compute it for all values of C
C = 0
(A' + B + 0)(A' + B + 1) =
(A' + B ) (1) =
(A' + B )C = 1
the same... the expression is simmetrical toward C
let's do it...
(A' + B + 1)(A' + B + 0) =
(1 ) (A' + B) =
(A' + B )So...
(A' + B + 0)(A' + B + 1) = (A' + B )
Let's put in the rest
(A + B)(A' + B )
same thing as before
A = 0
(0 + B)(1 + B ) = B(1) = B
A = 1 the same as before...Solution is
(A + B)(A' + B + C)(A' + B + C') = B
Make a truth table to convince yourself the the expression depends only on B and it's indifferent respect A and C
for the second one, if i simplify it by that, i get
(A + ABC) + (A'BC + A'B) + (DA + DA')
= A(1+BC) + A'(BC + B) + D(A+A')
= A + A'(B(C+1)) + D
= A + A'B + D
= (A + A'B) + D
= A + B + D
is that really it's simplest form?
