Transforming Sin(x) to Y=X
  • Thread starter Tido611
In summary, to turn a sin curve from a horizontal graph to a 45 degree, y=x graph mathematically, you can use a rotation matrix with an angle of -45 degrees. This will give you a new equation where y' is written in terms of x'. Be careful with the placement of the minus sign when rotating the coordinate axis or the function itself.
Tido611
79
is there a way to turn a sin curve (sin(x)) from a horizontal graph to a 45 degree, y=x graph mathematically
Yes.
Your initial equation is y=sin x
Put
[tex]x = x' \cos \theta - y' \sin \theta[/tex]
[tex]y = x' \sin \theta + y' \cos \theta[/tex]
where, in your case [itex]\theta = 45[/itex] degrees.
Then, your new equation is:
[tex]\frac{1}{\sqrt{2}}(x' + y') = \sin \left[ \frac{1}{\sqrt{2}}(x' - y') \right][/tex]
Now, the only problem you have is to rearrange this so as to write y' in terms of x'.
You rotated over an angle of -45° because your minus-sign was placed wrongly. You have to be careful whether it's the coordinate axis which are being rotated or the function itself. In this case, the rotation matrix is:
[tex]\left( {\begin{array}{*{20}c}
{\cos \theta } & {\sin \theta } \\
{ - \sin \theta } & {\cos \theta } \\
\end{array}} \right)[/tex]
giving the new equation:
[tex]\frac{1}{\sqrt{2}}(y' - x') = \sin \left[ \frac{1}{\sqrt{2}}(x' + y') \right][/tex]
Fair enough.
1. How do you transform Sin(x) to Y=X?
To transform Sin(x) to Y=X, you need to use the inverse trigonometric function Arcsin(x). This function will give you the value of x when Sin(x) is equal to a given value of y.
2. What is the purpose of transforming Sin(x) to Y=X?
The purpose of transforming Sin(x) to Y=X is to make the equation easier to solve. It also helps to understand the relationship between the angle and the sine value.
3. Can you explain the process of transforming Sin(x) to Y=X?
To transform Sin(x) to Y=X, you first need to isolate the Sin(x) term on one side of the equation. Then, use the inverse trigonometric function Arcsin(x) on both sides to eliminate the Sin(x) and get the value of x in terms of y.
4. Are there any restrictions when transforming Sin(x) to Y=X?
Yes, there are some restrictions when transforming Sin(x) to Y=X. The value of y must be between -1 and 1, as the range of Sin(x) is between -1 and 1. Also, the domain of Arcsin(x) is -1 to 1, so the value of x must be within that range.
5. How can transforming Sin(x) to Y=X be applied in real life?
Transforming Sin(x) to Y=X can be applied in fields such as engineering, physics, and mathematics. It can be used to solve problems involving angles and sine values, such as finding the height of a building or the length of a side in a right triangle.
  • Precalculus Mathematics Homework Help
