Single Phase Voltage from 3-Phase Line: Explained
In a 3-phase line with a 25kV line-to-line voltage, the voltage of a single phase line is typically 14.4kV when referenced to a neutral. This is calculated using the formula L-N = Vl/sqrt(3). Single phase transformers are used to convert the higher voltage to a user-friendly level, and the neutral is essential for creating a complete circuit. In distribution systems, the preference is for line voltages without using the neutral directly, and the single phase voltage is determined by transformer ratings. Overall, the single phase voltage does not remain at 25kV but is stepped down to a safer level for distribution.
louie
If I'm considering a 3 phase line (25kV line-to-line voltage) that comes to a point and splits into single phase lines, what is the line voltage of one of the single phase lines ?
Does it remain 25 kV or is it 14.4 kV because you're only dealing with 1 phase and a neutral now ?
Any explanation would be great
Louie
Normally, they do not distribute L-N = Vl/sqrt(3)=14.4kV, only L-L =25kV. The phases can split AB, BC, CA. The single phase transformers convert 25K--> user voltage with the ground reference applied at the secondary neutral.
A single phase line by definition is a circuit with only one phase. So you need a neutral side to create a loop. The voltage differential between the line and the neutral is, of course, +/- 14.4 kV and not 25 kV.
If you use both line (AB, AC, or BC) ... I don't think that a single phase line. It may be within the category of two phase line :-)
aaNg
For distribution purpose only line voltages preferred so neutral is not used. And 25KV will not be splitted into single phase directly it will be step downed and than you will get a sinle phase line. sinle phase line voltage depends on the transformer rating.
rgds
Mahadev
Actually, The main method of urban and suburban over head and URD is done single phase with line-neutra *in the usa*, europe is 3-phase secondary distribution 3-phases+ 2*line voltage = 8* the secondary line distance over the US, the neutral designation is MGN, or multiple grounded neutral, It is a lower wire of the four, or sometimes used as a top wire overhead shield in lightning prone areas. the L-N is used as the final distribution to the LNL +120 N -120 final use in typical residential apps.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
