B Are Larger Black Holes Less Dense Than Smaller Ones?
Black holes and singularities are often described as having infinite densities, but this is misleading when considering their actual volume. The density of a black hole is calculated as its mass divided by the volume within its event horizon, which can lead to lower densities for larger black holes. As a black hole's mass increases, the volume of space it occupies also increases, resulting in a decrease in density. This means that larger black holes can have significantly lower densities compared to smaller ones, as the volume grows more than the mass. The relationship between mass and volume in black holes highlights the complex nature of their geometry and density.
Will Langas
What has a higher density? Black Holes or Singularities?
I looked online and all I saw was that they both have infinite densities.
Astronomy news on Phys.org
The density of a black hole would be computed as its mass over its volume - the volume within the event horizon. So that would be far from infinite.
A black hole with zero angular momentum should have an embedded singularity where almost all of the black hole's mass will be accumulated. I'm not sure if makes sense to talk about its volume at all, but if it has one perhaps it is zero. Of course, if it is zero, that would give it "infinite density".
Likes Hoophy
I heard that a black hole can have a extremely low density. Also I heard that the bigger the black hole the lower the density. This does not make much sense to me, is it true? And if so can someone explain why?
As I said in the previous post the "size of a black hole" is generally taken to be the diameter of its event horizon. The actual geometry of the black hole is pretty involved - but as a simplification, imagine that all of the mass of the black hole is concentrated in a singularity, a point, at the center. The size of the event horizon is the sphere around that point where light cannot escape. If you double the mass at the center, the distance to the event horizon increases so the total volume of the black hole increases. That total volume will more than double. So, heavier black holes are less dense because they can enclose more empty space.
Interestingly, it is the surface area of the black hole (the event horizon) that increases proportionately to the mass.
Likes Hoophy
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
