Size of Neutron: Is It the Same as Proton?
  • Thread starter nuby
  • Tags
    Neutron
In summary, the conversation discusses the mass and diameter of protons and neutrons, as well as their composition and structure. It is mentioned that concepts like diameter and orbit are not applicable to subatomic particles, and that the size of a particle is defined by its interactions. There is also mention of a model called t'Hooft's dual-color-superconducting model of the vacuum, which is used to explain confinement in particle interactions. The conversation ends with a discussion on the unresolved question of particle structure and the ongoing research and study in this field.
nuby
336
If a proton and neutron have a mass of roughly 1.67e-27 kg . And a proton has a diameter of 1.65e-15 ..
Is the diameter of a neutron the same?
For all intents and purposes they are about the same. But concepts like diameter or radius in the context of small spheres, like ball-bearing in our everyday experience, are meaningless when applied to subatomic particles.
Thanks.
Astronuc, The "diameter" is more of a orbital boundary, correct?
Hi
It will be hard and long to make sens of such a concept in the case hadrons. It is doable, it has been done, but there is virtually no experiment shedding light on this specific approach to hadron structure.
The problem if you talk about "orbit" is that you have to take both position and momentum in the game. With ultra-relativistic light quarks confined in a proton/neutron, there is a long and technical path before you reach any kind of reward. What has been done for long and measured is effective electromagnetic radius for instance. You can interpret that as a position charge distribution density, without reference to momentum.
If the diameter is the same, then the density must be roughtly the same as well. The difference between composition of neutron and proton is that neutron is made up of 2 down quarks and 1 up quark while proton is made up of 2 up quarks and 1 down quark. I am not sure of the density of the up and down quarks but if they are roughly similar they the conclusion that the diameter of neutron thus its density is roughly similar to that of a proton is true.
Usually the linear size of charged particle is Compton wavelength (1.65e-15 m is c.w. of a proton)
[tex]\lambda_C = \frac{\hbar c}{m c^{ 2 }}[/tex]
Therefore if neutron had been charged its size would has been equal to proton size, proton and neutron have about same [tex]\lambda_C[/tex] as [tex]m_{p} \approx m_n[/tex]. Your question is not trivial because size of a particle is defined trough forces of its interactions.
I am not too sure about those agruments. What is the Compton wavelength of a u or d quark ? How does it compare with the size of a nucleon ? What can we conclude about the semi-classical approximation of a static-potential like confinement scenario, such as t'Hooft's dual-color-superconducting model of the vacuum ? Can we re-interpret this model in terms phase transitions a la Gribov ?
It's good example, quarks are very strongly interacting particles, their sizes are not defined trough their Compton wavelengths.
This model and tricks are not well-known for me, may you advise to me some good books and/or articles about it with rapidly clear explanation?
Thanks, I'll taste it.
I was surprised to find a neutron weighed more than a proton as I always thought a protron
as a neutron with a positive electron inside it (or something like that).
But then maybe a neuton is is a proton with an electron inside it?
Actually if you look at the atomic weights a neutron is probably a proton with three electrons stuffed inside it.
Has this been confirmed by atom bashing?
no it weight more due to its different quark composition.
And atomic weight of a neutron? Huh?
esbo said:
I was surprised to find a neutron weighed more than a proton as I always thought a proton as a neutron with a positive electron inside it (or something like that).
But then maybe a neutron is is a proton with an electron inside it?
Something like this is what appears on: http://www.terra.es/personal/gsardin/news13.htm
There is a lot that can be done with this and values that have been discarded such as the Classical Radius; but the difficulty is that there are no forums where incomplete theories (i.e. theories under development) are taken seriously and it is of course, inappropriate to mention them on other forums.
'Atom bashing' experiments use a selective computer program with the result that only two or three results, out of each batch of 80,000 results; are selected for investigation. This has lead to the PDG pointing out that experimental results are theme related.
The whole question of particle structure is unresolved.
Maybe you can explain us what you know about particle physics ?
In most of those laboratories, and universities as well, one can count several hundreds, even thousands, of people whose daily purpose is to unravel those structures. They are working hard, and have been studying for a long time. You might be very surprised, if you took time to pay them a visit, to realize that they are not that close minded at all. On the contrary. But also, you might be surprised if you would take the time to seriously try to understand what they do, to realize that they are making continuous progress on our understanding. You will not find their latest understanding in the textbooks, because it is still considered speculative. You do need however to go through the textbooks in order to read the published articles, which is where you will find reports on what they are currently doing.
edit
I emphasized published because you are more than welcome to publish you own theory so that we discuss it here.
humanino
I have never said they were. The crux of my case lies in the second part of your reply:
My work has been dismissed as ‘speculation’ so where does one go to debate speculative theories. Professionals, as you point out; have there associates in laboratories and universities but, the only hope for the complete amateur is the internet; but then comes the catch, only published works are eligible for debate on any forum worth calling a Science Forum.
All my work is done by re-arranging PDG listings, Tables of Elements and tables published in papers on Hall fractions; to show mathematical relationships that have (as far as I am aware) not been published. So I am looking for a forum on speculations, where the moderators decide what is worthy of serious debate and reject the pseudo-science; if my work were then rejected (with reason) then although disappointed, I would at least, know where I stand. But to be rejected as speculation, without reason, leaves me uncertain as to whether I should continue or give up.
(Debate precedes progress.)
Humanino: "I emphasized published because you are more than welcome to publish you own theory so that we discuss it here."
I don't know where the boarder lies between "own theories" and "own/speculative theories" that is mentioned in the forum rules.
Sorry, I was not clear.
People are welcome to publish their theories in peer reviewed papers (read : somewhere else) so that we can discuss them here. :smile:
1. What is the size of a neutron compared to a proton?
The size of a neutron is slightly larger than that of a proton. This is because a neutron contains one additional subatomic particle, the neutral charge carrier known as the neutron. The exact size of a neutron can vary, but it is typically around 0.8 femtometers (fm) while a proton is approximately 0.7 fm.
2. Why are neutrons and protons considered to be similar in size?
Neutrons and protons are considered to be similar in size because they are both classified as baryons, which means they are made up of three quarks. The quarks inside a neutron and a proton are the same type (up and down quarks), but they have different numbers and arrangements, resulting in slightly different sizes.
3. Is the size of a neutron and proton constant?
The size of a neutron and proton is not constant. Their sizes can vary depending on the energy state and environment in which they exist. Additionally, in high-energy collisions, neutrons and protons can break down into smaller particles, resulting in even smaller sizes.
4. What is the importance of knowing the size of a neutron and proton?
Knowing the size of a neutron and proton is important in understanding the structure of the atom and the fundamental particles that make up matter. It also helps in studying nuclear reactions and the behavior of particles in high-energy environments, such as in particle accelerators.
5. How do scientists measure the size of a neutron and proton?
Scientists measure the size of a neutron and proton using a technique called scattering experiments. This involves firing particles, such as electrons or protons, at a target containing neutrons or protons and measuring the scattering pattern. By analyzing the pattern, scientists can determine the size and structure of the particles being studied.
  • High Energy, Nuclear, Particle Physics
