Are there limitations to detecting small objects using sound and light?
  • Thread starter Thread starter nickek
The discussion highlights the limitations of detecting small objects using sound and light, emphasizing the role of wavelength in resolution criteria. It distinguishes between 'detecting' and 'resolving,' noting that detection relies on signal-to-noise ratio rather than wavelength, allowing for the identification of subresolution objects without detailed information about their size or shape. Bats exemplify this concept, as they can detect prey and infer characteristics from the strength of the return signal, despite not having high-resolution sonar images. The conversation also touches on diffraction limits, which complicate the ability to discern whether multiple objects are present in a given area. Overall, understanding these principles is crucial for exploring the capabilities and limitations of sensory detection in various contexts.
nickek
Hi!
In a book, there is stated that the least detectable object by a bat is when the object is λ/2 of the sound wavelength emitted by the bat. I know there is resolution criteria for light microscopes too, which concerns the wavelength of the light.
My question is: Are these criteria about the phenomena of interference of waves or something else? Or maybe it is possible to detect the objects smaller than this size, but we can not get any information about size or form from them if the wavelength is too long?
nickek said:
<snip>My question is: Are these criteria about the phenomena of interference of waves or something else? Or maybe it is possible to detect the objects smaller than this size, but we can not get any information about size or form from them if the wavelength is too long?
There's at least one important difference between 'detecting' and 'resolving'- while 'resolving' does involve the wavelength of light (or sound), 'detecting' does not- detection only depends on the signal-to-noise ratio, which can be quite high even for subresolution objects. Also, it is true that detection of a subresolution object does not provide any information about the size/shape/etc. of the object.
One good example is stars. Naked eye resolution is about 1 arc minute (60 arc minutes = 1 degree) so we can only resolve one star (the sun at ~30 arc minutes) but there are thousands of stars we can detect given reasonably dark skies (good SNR).
Thanks for answers, everyone. Now I have a starting point for curious students asking about this task.
Bats have a significant amount of brain power and they can deduce a lot about what their target is without needing a high resolution sonar image. They can detect a target and know its distance. The strength of the return signal is a good indication of size because the reflectivity of their prey species will be much of a muchness (unlike the range of brightnesses of stars, for instance). They can then go closer and 'investigate' - unlike astronomers with their stars.
Diffraction (resolution) limits, optical and sonar are a bigger problem when it comes to deciding whether it's one or two objects you are looking at. The eye can see many points of light up in the night sky which are, in fact two or more bright objects.
Likes 1 person
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
