Calculating Quark Radius from Mass Equation
The discussion centers on the assumption that quarks are not point-like but rather have a measurable size, based on a derived mass equation that relates quark mass to their radius. Calculations suggest that the radii of up, charm, and top quarks are approximately 10^-18, 10^-19, and 10^-22 meters, respectively. This challenges the quantum field theory perspective that treats charges as point particles, as the integral used only provides a range between initial and compressed radii. Participants express skepticism about determining an exact radius for quarks, noting that no particle smaller than quarks exists for experimental verification. The conversation also touches on the theoretical implications of quark size and the potential for future research into mass ratios of particles.
kurious
When I use the following equation which assumes quarks are spheres of charge and compressing the spheres creates mass (by doing work):
mass of quark = integral of ( k q ^2 / r^2 c^ 2 ) d r
and input masses from the mass equation I arrived at by trial and error a few months ago in which n is an integer
Mass = [12.50 x 10^3pi (n – 5) / 2 0] x ( n – 4 )^ 2 x 10^ 39 ( n – 3 ) / 2 x 10^57 x q ^n
I get radius of up quark,charm quark and top quark to be around 10^-18,
10^-19 and 10^-22 metres respectively.
If I am right this means that the assumption of quantum field theory that charges are pointlike is incorrect.However the integral only allows me to obtain [ 1/r] between r1 and r2 where r1 is initial radius and r2 is compressed radius of a sphere.Can anyone think of a way to get r1 exact for a quark?
By collision experiments, the sizes of particles were determined.
Rutherford bombarded the gold atoms with alpha particles and deduced the existence of the nucleus.
In high energy physics, the nuclei were bombarded by other elementary particles and the existence of quarks was established.
In order to find the size of quarks, it has to be bombarded by something that must be smaller than the quarks. No such thing exist in nature. That is why quarks and the leptons are considered point particles.
kurious
You have been transferred to theory development, where according to PF moderator chroot all the nutcases are dumped, a hearty welcome!
Antonio is half right. Quantum physicist consider quarks to be pointlike, Particle physicist give them a minimum size based on Planck length.
I am intrigue by your claim because I have related quark mass to quark volume, but the volume and radii are in arbitrary numbers because I am unable to get a real quantity for any particular particle measurement other than mass.
Would you please take a look at http://elasticity2.tripod.com/ and let me know if we can cooperate to produce something meaningfull.
My research in the quantization of one dimensional space requires the existence of minimum quanta of length. I am not quite sure whether this minimum length is the same as the Planck length. But since I am using matrices instead of actual values for the length and forces, I don't need to specify the values for them.
My postdiction is to calculate the mass ratio of a proton to an electron by these matrices and derive a value for the mass ratio to be within a percent of the actual experimental value. I can continue to find mass ratios for all the other particles but a strong evidence for stable particles of proton and electron is sufficient for me at this time.
Lao, is there any specific evidence to say that they do not exist? I'm sure at some point in time there wasnt anything to show that quarks existed, either?
Quarks and leptons in all practical purposes are point particles, their dimensional extension are zero. But their existence is due to their mutual interactions by their mass and charge properties and energy transformations.
The interaction of the quantum of length that I have in mind is zero because the field is scalar that is to say that a force cannot be detected by experiment although the fluctuation of vacuum does indicate the existence of quantum of length. But if there is a quantum of length such as Planck length why does the force cannot be detected at this length?
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
