Sketch the form of the Fourier transform - is this right?
Zomboy
"Sketch the form of the Fourier transform" - is this right?
Question ~ sketch the "form of the Fourier transform" for the function:
f(k) = sin^2(ka/2) / (ka/2)^2So I'm thinking it will look like a cos [or sin] graph (shifted so that its 'above' *f(k)=0*) and that there will be some sort of *central* highest maximum and then the hight of the peaks tends to 0.
*** My question is does this graph have one highest maximum when k=0 or does it have two highest maximums either side of the origin spaced evenly from the origin [k=0]?
At the moment I'm thinking there will be two highest maximums which occur at -π/2 and π/2. Also, that when k = 0, f(k)=0.
Later on however in the question it implies that there is one central maximum:
"...find the values of k when f(k) first becomes zero either side of the central maximum at k=0..."Any advice?
There is a concept called the sinc function.
sin(k/2)/(k/2) = sinc(k/2)
The function has one maximum at k=0, and is symmetric across k = 0. You function is the square version of this function, when the variable is taken to be ka/2.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
