Sketching the closure of a set
  • Thread starter Thread starter Benzoate
    closure Set
Benzoate
Sketch the closure of the set:Re(1/z)=< 1/2[ b]2. Homework Equations [/b]
Re(1/z)=Re(1/(x+iy)
Re(1/(x+iy))=< 1/2. Not really sure how to sketch 1/2 on a complex plane. Maybe 1/2 can be written in a complex form: 1/2= (1/2)+(0)*i=1/2 and therefore , 1/2 only lies exclusively on the x-axis.
Not even entirely sure how to sketch the Re(1/z) on a complex plane. Generally, Re(z)=x and therefore would Re(1/z)=1/x?
Benzoate said:
Re(1/z)=Re(1/(x+iy)
Hi Benzoate! :smile:
ok … now you need to simplify this fraction so that you can just read off the real part.
The standard trick is to multiply top and bottom by (x - iy). :smile:
so Re (1/z) = Re(1/(x+iy))=Re(1/(x+iy)*(x-iy)/(x-iy))=Re(x-iy)/(x^2-y^2)). How will this new expression make it easier for me to mapped Re(1/z) in a complex plane. In addition, how would I mapped 1/2 on a complex plane? Does 1/2=1/2+0*i
First … it's Re(1/z) = Re(x-iy)/(x^2 + y^2), not x^2-y^2 :wink:
second … Re(x + iy) < 1/2 if … ? :smile:
Only if x less than or equal to 1/2 and y is less than or equal to zero
Wouldn't Re(x+iy/(x^2+y^2)) Be sketched only on the x-axis since all real numbers lie only on the x-axis. Would it be correct to say that 1/2 lies only only the real part of the complex plane since 1/2=1/2+i*0?
No … the value of y doesn't matter …
Re(x+iy) = x …
so Re(x+iy) < 1/2 just means x < 1/2 …
so Re(x+iy) < 1/2 for x < 1/2 and for all y. :smile:
Forget 1/2.
And you're not sketching Re(x+iy/(x^2+y^2)).
You're sketching x + iy such that Re(x+iy/(x^2+y^2)) ≤ 1/2.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
