How Does a Small Solar Cell Achieve High Amperage?
Small solar cells can achieve high amperage ratings, such as 1000mA to 2000mA, by utilizing internal supercapacitors that store energy. These capacitors charge slowly from the solar cell and then discharge quickly to provide a high current output when needed. The design allows for efficient energy transfer, enabling devices like solar chargers to deliver significant power despite their compact size. This method effectively bridges the gap between low solar cell output and high device demand. Understanding this technology can clarify how small solar chargers function effectively.
ramonegumpert
dear experts
i saw a solar charger the size of an iphone that has high amperage rating of over 1000mA to 2000mA.
Based on the solar cell size i estimate it to produce at most 250mA at around 5 volts.
I like to know how the high amperageis derived.
is it using super capacitors ?
if so , is it charging up the sc and them discharging to battery at high amperage like 1000mA?
Thanks for reading.
best regards
Ramone
It may be slowly charging some cells inside its box. You can quickly charge your phone battery by connecting to these cells.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
