Well it does seem that mathematicians here are not that in touch with the name, or simply not interested. Anyways, I do find the concept,
now that I understand it much better, that in reality is simple, but highly useful. Nevertheless it may give the impression of being somewhat arbitrary for the one who sees its applications to solving problems, for the first time. For those who do not know much about it, or may have seen it but didn't understand like me (or no one could explain to you...
) here is a Lemma statement (probably a theorem, but I haven't seen it, yet, generalized for more than two numbers), and my
proof.
Lemma:
The product of any real numbers can be increased under the constraint i, if and only if the following condition ii, is met.
i) The sum of the numbers is fixed.
ii) The difference between the numbers is decreased.
Proof:
Let \left\{a_i\right\}_1^n be a sequence of real numbers. Define the transform T:\left\{a_i\right\}_1^n\rightarrow \left\{\alpha\right\}_1^n that will replace all the a_i with \alpha = \displaystyle \sum_{i=1}^n \dfrac{a_i}{n}.
Under the transformation, \displaystyle \sum_{i=1}^n a_i is fixed since
\displaystyle \sum_{i=1}^n a_i = \displaystyle \sum_{i=1}^n \alpha = n\alpha = \dfrac{n}{n}\displaystyle \sum_{i=1}^n a_i = \displaystyle \sum_{i=1}^n a_i
In addition, notice that the difference between any elements of \left\{\alpha\right\}_1^n is zero or minimized, since all the \alpha_i are equal. Hence, the conditions i,ii of Lemma are satisfied, and we only need to show
\displaystyle \prod_{i=1}^n \alpha > \displaystyle \prod_{i=1}^n a_i.
By AM-GM inequality
\begin{eqnarray*}\displaystyle \left(\sum_{i=1}^n \dfrac{a_i}{n} \right)^n \geq \displaystyle \prod_{i=1}^n a_i \end{eqnarray*}
Case 1. All the a_i are equal.
Then
\left(\displaystyle \sum_{i=1}^n \dfrac {a_i}{n}\right)^n = \displaystyle \prod_{i=1}^n a_i = (maximum product),
by AM-GM condition for equality. The sum \displaystyle \sum_{i=1}^n a_i is fixed. The difference between any of the a_i
is zero or minimized since they are all equal; hence the difference between the a_i can not be decreased. Since condition ii of Lemma is not satisfied, Lemma states that the product can not be increased while having the sum fixed.
Since by AM-GM the product is maximum, the product can not be increased while having the sum fixed. Hence, Lemma is true when all a_i are equal.
Case 2. Not all the a_i are equal.
By AM-GM condition for strict inequality,
<br />
\displaystyle \left(\sum_{i=1}^n \dfrac{a_i}{n} \right)^n > \displaystyle \prod_{i=1}^n a_i <br />
<br />
\Leftrightarrow \alpha^n &>& \displaystyle \prod_{i=1}^n a_i <br />
<br />
\Leftrightarrow \displaystyle \prod_{i=1}^n \alpha > \displaystyle \prod_{i=1}^n a_i <br />
<br />
as required. Therefore Lemma is true when not all a_i are equal.
Since Lemma is true when all a_i are equal, true when not all a_i are equal, and there is no other relevant case, Lemma is true.
For the Math people out there, I receive any comments on the proof or else, very gratefully, as I am relatively new to this interest...
