Soap bubble measures electric field
Determining a local electric field using the interference spectrum of a soap bubble is theoretically possible, but practical challenges exist. The random turbulence of colors in the bubble, influenced by air currents and internal movements, complicates quantifying any changes in iridescence due to an applied electric field. While isolating a single bubble for controlled study could mitigate some variables, temperature variations may still pose significant difficulties. The dynamic nature of soap molecules contrasts with the static nature of crystallography, making the process potentially more complex. Overall, while the idea is intriguing, practical execution may prove challenging.
Loren Booda
Can one determine a local electric field by the change in interference spectrum of a soap bubble? If one notes the spectrum with E=0, then applies a nonzero E-field, would the effect of the induced repulsive charge on iridescence be relatively easy to calculate, given the additional variable of local surface tension?
Mmm...I'm not sure that would be very easy, since the turbulence of the colors in the bubble are so random already, and depend on things like surrounding air currents, currents within the bubble, and so on...and it would probably be very hard to quantify any such change even if it is visible.
Interesting idea though!
I don't see why not in principle, wouldn't it be similar to crystallographic methods?
I don't think its so difficult to isolate a single bubble and study it in controlled conditions, using already available techniques. I think temp variations would present the biggest difficulties. I am not very familiar with the details of X-Ray Crystallography though, but its a topic that I am very interested in at present.
It would probably be a lot harder than X-ray crystallography, since the molecules in a soap bubble are not crystallized and static; rather, they move around a lot. I would guess that when an electric field is applied, the polar water molecules would tend to line up somewhat with the field, but the effect wouldn't be visible since the thickness of the water and soap films would still be about the same as with no field. Of course, I could be completely wrong. If you can, try this out!
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
