Uncovering Wavelengths Not Reflected in a Soap Bubble Film
A soap bubble 500 nm thick with a refractive index of 1.35 is illuminated with white light, leading to discussions on which wavelengths are not reflected. The interference of light waves, specifically the phase changes upon reflection, determines the wavelengths that are canceled out rather than reflected. The equations provided, 2nt=mL and 2nt=m(L/2), are used to calculate the conditions for constructive and destructive interference. Participants express confusion about the problem's requirements and the principles of thin film interference. Understanding these concepts is crucial for solving the problem accurately.
rgold
1. The problem statement, all variables and given/known da
A soap bubble 500 nm thick is illuminated with white light. The index of refraction of
this unique soap film is 1.35 for all colors (no dispersion). a) What wavelengths are not
reflected?
2nt=mL
2nt=m(L/2)
for m=1 2(1.35)(500nm)=1350nm
for m=2 =675nm
am i doing this right? i do not really understand what the question is looking for.
rgold said:
[A]m I doing this right?
Please explain your reasoning.
I do not really understand what the question is looking for.
... then you are probably not doing it right.
Even if you got the right answer, it would only be by accident.
Why would some wavelengths not get reflected off the soap bubble?
Likes gracy
If they get absorbed they would not be reflected right? But I don't know how to translate this
Not quite: the light does not have to be absorbed.
You have probably just done a section on thin films. Recall that it depends on interference: the reflected ray off the bottom (inner) surface of the bubble interferes with the reflected ray off the top (outer) surface. Also recall that reflection may involve a phase change.
If you missed it in class here's a crash course:
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/thinfilm.html
You can find other examples online under "thin film physics".
